LCD 20X4 connect with DS1820
Results 1 to 7 of 7
    jojokatada's Avatar
    jojokatada Guest
    Default LCD 20X4 connect with DS1820
    'display message on the 4 X 20 character LCD using pic16f84a and DS1820
    DEFINE LCD_DREG PORTA 'LCD data port
    DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTA 'LCD register select port
    DEFINE LCD_RSBIT 4 'LCD register select bit
    DEFINE LCD_EREG PORTB 'LCD enable port
    DEFINE LCD_EBIT 3 'LCD enable bit
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_LINES 4 'Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 'Command delay time in us
    DEFINE LCD_DATAUS 50 'Data delay time
    symbol DQ = PORTB.4
    temp var word
    cou var byte
    cou1 var byte
    owout DQ, 1,[$CC, $44]
    owin DQ, 4,[cou]
    if cou = 0 then
    owout DQ, 1, [$cc, $BE]
    owin DQ, 0,[temp.lowbyte, temp.highbyte, skip 4, cou,cou1]
    temp = (((temp >> 1) * 100) - 25 ) + (((cou -cou1) * 100) / cou)
    lcdout $fe, 1, dec (temp / 100), " . " , dec2 temp, " C"
    Please help take alook at my attchment i got many error which i could not solved
    Unhappy
    hummm no error here when compiling your code. Looks like your PBP .INC, .BAS files are corrupted...
    Reinstall your PBP and MPLAB an tell us what's happening.
    jojokatada's Avatar
    jojokatada Guest
    Default lcd 20x4 with ds1820
    i am using microcode studio suite a free software and picbasic pro 2.3 i only unzipped the pbp to drive c of my pc
    Reason is simple now. Version 2.3 don't support OWIN and OWOUT.. must buy an upgrade disk.
    http://www.melabs.com/support/upgrade.htm#pbp
    jojokatada's Avatar
    jojokatada Guest
    ok thank you for the advice
    jojokatada's Avatar
    jojokatada Guest
    hi
    is it possible to use 4 ds1820 a pic16f84a which will be display four different temperature on the 4 lines of the lcd?
    with my single ds1820 how can i edit to make it work for 4 ds1820
    any help will be highly appreciated.
    Ceug2005's Avatar
    Ceug2005 Guest
    Thumbs up
    $55 - match ROM
    $10,$BB,$40,$2C,$00,$08,$00,$F9 - 64 bit rom code for sensor 1
    $44 - do temp conversion
    sensor 1:
    OWOUT PortB.0, 1, [$55,$10,$BB,$40,$2C,$00,$08,$00,$F9,$44]
    ' match ROM &
    pause 1000 ' conversion time 750 ms
    OWOUT PortB.0, 1, [$55,$10,$BB,$40,$2C,$00,$08,$00,$F9,$BE]
    ' match ROM & read scratchpad memory
    OWIN PortB.0, 2, [R_Temp0.Lowbyte, R_Temp0.Highbyte,skip4,count_remain_0,count_per_c_ 0]
    same for sensor 2,3,4 --- if you heave enough space in PIC16F84
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 04:59
  3. Pic18f452 with 20x4 LCD Help
    By djmachine in forum mel PIC BASIC Pro
    Last Post: - 6th November 2008, 22:43
  4. Play with LCD on PICDEM
  5. Need help with LCD number display.
