Comparator circuit thoughts....
Results 1 to 16 of 16
    Dec 2005
    Salt Lake City, Ut, USA
    Major stupid question...
    If I declare something like Number var BYTE...
    Then I do: Number = 1.01567
    Does that get truncated to 1, or something else, or rejected altogether?
    Wow, I feel like a moron for asking! Sorry.
    Chris
    No problem with the questions.....
    Unless you get into floating point routines we are stuck with integer math.
    But if You need to be more accurate there are ways to do so. Basically mutiply by a power of ten and ...... Well you get the idea.
    So it would become 1.
    The PBP manual has a good section about the math.
    Dec 2005
    Cool... I guess I'll put this mess up for you to take a look at. Mark it up at will. Thanks a ton....and here goes
    '   Name    : THC.BAS
    '   Author  : Me
    '   Notice  : Copyright (c) 2009 None
    '          : All Rights Reserved
    '   Date    : 10/20/2009
    '   Version : 1.0
    '   Notes   :
    include "MODEDEFS.BAS"
    '\\\\ADC DEFINES////
    DEFINE ADC_BITS 8       'Number of bits in ADCIN result
    DEFINE ADC_CLOCK 3      'ADC clock source (rc = 3)
    DEFINE ADC_SAMPLEUS 50  'ADC sampling time in microseconds
    CVRCON = 143            'Reference on, not tied to pin, set to 3.59vdc
    ANSEL = 64              'Enable analog select, select channel 6
    CMCON = 7
    '\\\\SERIAL PORT SETUP////
    DEFINE HSER_RCSTA 90h   'Enable serial port
    define HSER_TXSTA 24h   'Enable transmit
    define HSER_SPBRG 25    'Set baudrate to 9600
    DEFINE HSER_CLOERR 1    'Automatic clear overrun error
    INTCON = 64             'Enable peripheral interrupts
    PIE1 = 32               'Enable AUSART receive interrupt
    '\\\\PINS SETUP////
    TRISB.0 = 0             'Up LED Output
    TRISB.1 = 1             'Enable THC Input
    TRISB.3 = 0             'LCD Pin
    TRISB.4 = 0             'Dn LED Output
    TRISB.6 = 0             'THC Enabled LED Output
    TRISB.7 = 1             'Scaled Torch Voltage Analog Input
    '\\\\VARIABLE DECLARATIONS////
    TargetVDC var byte      '000-256 Allowed
    TargetVDCDiv var byte
    TorchPin var PORTB.0
    TorchVoltsNow var byte
    TorchDown var PORTB.4
    TorchUp var PORTB.0
    EnableIn var PORTB.1
    TorchVoltsFull var byte
    '\\\\POWER UP STARTS HERE////
    Pause 500               'Wait for LCD to startup
    TargetVDC = 120         'Start up target volt value
    '\\\\LOOK FOR SERIAL DATA ON AUSART RX PIN////
    on interrupt goto NewSerialData
    NewSerialData:
    hserin [wait ("V"),DEC3 TargetVDC]
    TargetVDCDiv = TargetVDC / 256
    goto mainloop
    '\\\\START MAIN PROGRAM LOOP HERE////
    Mainloop:
        IF Enablein = 1 then
            ADCIN 6,TorchVoltsNow
            if torchvoltsnow > TargetVDCDiv then
                high torchup    'Turn off TorchUp Pin
                low torchdown   'Turn on TorchDown Pin
                high Torchdown  'Turn off TorchDown Pin
                Low torchup     'Turn on TorchUp Pin
        TorchVoltsFull = TorchVoltsNow * 256
        '\\\\SEND STATUS OUT TO LCD////
        LCDOUT $FE, 1
        LCDOUT $FE, 2
        LCDOUT "PLASMA VDC : "TorchVoltsfull
        PAUSE 50
        LCDOUT $FE, $C0
        LCDOUT "TARGET VDC : "TARGETVDC
        PAUSE 50
        HSEROUT TorchVoltsFull
        LCDOUT $FE, 1
        LCDOUT $FE, 2
        LCDOUT "---CONTROL IS---"
        PAUSE 50
        LCDOUT $FE, $C0
        LCDOUT "----DISABLED----"
        PAUSE 50
    Goto mainloop
    Don't be cruel....newbie with ambition!
    Thanks a ton!
    Chris
    Dec 2005
    Default 1333
    Typo in:
    Change to
    TorchPin var PORTB.7
    This is for comparators
    CVRCON = 143
    you want
    ADCON1 = %00100000 'Pin #2 is voltage reference
    The LCD lines and HSEROUT line should be something like
    LCDOUT "TARGET VDC ", #TARGETVDC
    HSEROUT [#TorchVoltsFull]
    The divide by multiply by 256 should not be there. The 8bit ADC goes from 0 to 255. As we talked before withe the voltage divider feeding the ADC and using using the reference voltage. Well it worked pretty neat for you. The torch voltage will be the same "number" as the ADC value.
    Other than that it should do something
    Now I will toss something else at you.
    Think how fast the torch move up and down. Those few line of code before the ADC is read could mean trouble. You may want to increment the movement.
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 02:18
  2. Quick thoughts: DT Ints with encoders
    Last Post: - 7th January 2010, 01:01
