PBP bad expression
Results 1 to 4 of 4
    Oct 2009
    Post PBP bad expression
    Alright, I think I got a good one for ya here:
    I have a large main program that is calling subroutines from an INCLUDE file (include "umfpuV3-spi.bas"). These subroutines use variables that are defined in the main program file. For some reason, the compiler (PBPro 2.46) does not recognize these variables when inside the INCLUDEd subroutines, and I get the error "Bad Expression".
    These variables are PORT names, as shown in the code below. When I change the variable name to the PORTC.x name inside the INC file, the Main program compiles with no problem.
    To be specific, when the GOSUB FPU_RESET is called in the main program below, the FpuOut, FpuClk, and FpuIn are not recognized in the subroutine.
    Here is the header to my main program with the GOSUB:
    '              MAIN PROGRAM CODE
    '-------------------- PIC oscillator speed ------------------------------------
    define      OSC 20                      ' specify the speed of the oscillator
    OSC_SPEED   con 20                      ' define PICBASIC constant
    '-------------------- debug definitions ---------------------------------------
    define DEBUG_REG PORTD
    define DEBUG_BIT 0
    define DEBUG_BAUD 9600
    define DEBUG_MODE 0
    DEFINE DEBUGIN_BIT 1
    '-------------------- ADC CONFIG definitions ----------------------------------
    Define	ADC_BITS	    10	' Set number of bits in result
    Define	ADC_CLOCK	    3	' Set clock source (3=rc)
    Define	ADC_SAMPLEUS	5	' Set sampling time in uS
    TRISA = %11111111	        'Set PORTA to all input
    'ADCON1 = %10001100          'config of 877
    adcon1 = %00011000          'config for 4550
    TRISD.3 = %1
    '-------------------- INCLUDE files --------------------------------------------
    Include "modedefs.bas"      'Include for serial communication
    include     "umfpuV3-spi.bas"           ' include uM-FPU V3.1 support routines
    include "fp1832.bas"        'Floating point math
    '-------------------- uM-FPU pin definitions ----------------------------------
    FpuClk          var     PORTC.3			' SPI SCLK (uM-FPU SCLK)
    FpuIn           var     PORTC.4			' SPI MISO (uM-FPU SOUT)
    FpuOut          var     PORTC.5			' SPI MOSI (uM-FPU SIN)
    '-------------------- AD7715 calibration data ----------------------------------
        data @200, 0        'high byte of zs_mv
        data @201, 0        'low byte of zs_mv
        data @202, 0        'high byte of zs_adval
        data @203, 0        'low byte of zs_adval
        data @204, 4        'high byte of fs_mv
        data @205, 237      'low byte of fs_mv
        data @206, 233      'high byte of fs_adval
        data @207, 188      'low byte of fs_adval
    Reset:
      DEBUG 13, 10, 13, 10, "Demo 2: "
      GOSUB Fpu_Reset                       ' initialize uM-FPU
      IF fpu_status <> SYNC_CHAR THEN
        DEBUG "uM-FPU not detected."
        GOSUB Print_Version                 ' display version string
    *clipped*
    Here is the subroutine inside the .inc file. You can see where I changed the first SHIFTOUT to use the PORT pin numbers, and the second SHIFTOUT is using the variable names.
    '-------------------- uM-FPU SPI support routines -----------------------------
    Fpu_Reset:								' send reset command to uM-FPU V3
      SHIFTOUT portc.5, portc.3, 1,_
    	[$FF, $FF, $FF, $FF, $FF, $FF, $FF, $FF, $FF, $FF, 0]
      PAUSE 10
    										' check for synchronization
      SHIFTOUT FpuOut, FpuClk, MSBFIRST, [SYNC]
      GOTO Fpu_Status2
    Here is a WORKING main program. When I compile this program, the subroutine recognizes the variables and has no errors:
    define      DEBUG_REG   PORTC
    define      DEBUG_BIT   6
    define      DEBUG_BAUD  19200
    define      DEBUG_MODE  0
    '-------------------- DS1620 pin definitions ---------------------------------
    DS_RST      var     PORTA.0             ' DS1620 reset/enable
    DS_CLK      var     PORTA.1             ' DS1620 clock
    DS_DATA     var     PORTA.2             ' DS1620 data
    LSBFIRST	con		0					' shiftout mode
    LSBPRE		con		1					' shiftin mode
    '-------------------- uM-FPU register definitions ----------------------------
    DegC            CON     1               ' temperature in degrees Celsius
    DegC_Min        CON     2               ' minimum temperature
    DegC_Max        CON     3               ' maximum temperature
    DegF            CON     4               ' temperature in degrees Fahrenheit
    F1_8            CON     5               ' constant 1.8
    '-------------------- variables ----------------------------------------------
    rawTemp         VAR     Word            ' raw temperature reading
    '-------------------- initialization -----------------------------------------
    Reset:
      DEBUG 13, 10, "---------------------"
      GOSUB Init_DS1620                     ' initialize DS1620
    So ... granted that my MAIN program is very large (25K) and has many other things going on, does anyone know what a possible problem or solution could be?
    I'll be here all night...
    Put any variables or aliases used in the include file, before the INCLUDE statement.
    Oct 2009
    Default OMG you are amazing.
    I'm noticeably balder after that experience, and all for something so simple.
    Thanks Darrel. I love you.
    Quote Originally Posted by MyBuddy View Post
    I'm noticeably balder after that experience ...
    It happens ...
    Start the Rogaine now.
    One of our other users waited too long.
    __________________
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. Extensions to PBP variables
    By John_Mac in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2009, 05:21
  3. bad expression error, linking addresses incorrectly.
    By robertpeach in forum mel PIC BASIC Pro
    Last Post: - 26th August 2009, 13:04
  4. Compiler differences between PBP 2.33 & 2.46
  5. Newby- PBP wont compile for 18F (MPLAB)
