PBP 2.60 & ADCON1 problem
Results 1 to 5 of 5
    Question
    Everything fine. No error here ( Whether MPASM or PM used ).
    May be try to wipe off ( from the "add/remove program Windows menu ) and re-install PBP 2.60 ( default Folder used ??? )
    I don't use Microcode Studio so I can't comment there.
    For editing I use Notepad because what you see is pretty much what you get saved to Disk. But if you ever happen to use WordPad, Word or some other WP or Text Editor, they have a horrible habit of embedding all kinds of formatting and control codes which are invisible to you on the screen and which then serve to screw-up the Compiler.
  1. Replies: 14
    Last Post: - 19th January 2012, 20:38
  2. Strange problem with PBP 2.50
    Last Post: - 16th October 2007, 21:45
  3. Big Problem in PBP To receive DMX
    By programmer07 in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 19:49
  4. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 20:55
  5. Problem DEFINE OSCCAL and PBP 2.46
    By David in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2005, 18:19
