different voltaje a/d sensors
Results 1 to 22 of 22
    Dec 2005
    You should be able to do it with three Resistors and two additional PIC pins...
    I considered that but the OP seemed to be asking how to promote the 3.0V and 3.3V sensors so they are, in effect, 5V sensors. I don't think anything other than amplifying the signals accomplishes that.
    By changing ADCON1 on the fly (between AVdd & Vref+) you can simplify it further. Or, it can be simplified by using 3.3V for the thermistor circuit.
    However, it does assume that the OUTPUT LOW voltage is 0V which may not be the case. It may be as high as 0.6V @ 4.5Vdd.
    Actually you don't need to assume 0v. It can be 1v for all the divider Resistors care... choose the values for R2/R3 that will give you 3.3v/3.0v when that pin is LOW, if you assume 0.6v then you will be pretty close with a paper exercise. If it's a one-off build (or a product where a high degree of accuracy is required), the using Hi-Stab multi-turn pots and manually calibrating as I suggested is the way to go...
    Either way, it's just another suggestion thrown into the melting pot of ideas... another could be using an LM317 and using the PIC to switch-in different Resistor values for different voltages (depending on the current draw, that option could also power your Sensor as well as Vref+)... one could carry on throwing ideas around all night long...
    Wink
    Mel is Right ( as always !!! )
    For a project I am developping these days ... I use a DAC to feed the Vref + of the ADC ( external ...) and GND or a fraction of Vref+ as Vref - ...
    Note Vref+ is to change with atmospheric conditions ( NO, I didn't tell it's a barometer, ... nooooo ... )
    just to artificially enhance the ADC resolution ...
    Dec 2005
    Yeah - I realized that just after posting.
    May 2007
    I'm really amazed on how much options have appeared for the same operation thx all, and I have really learned from all of you, but...
    ...In my specific application, I must choose the closest possible to realtime AD option, and Melanies is a really great solution but it requires switching and waiting for a settling time for a succesfull digitalization.
    My application is an IMU, which means sampling 8 A/D as fastest as possible, then applying kalman, then PID, while doing PWM, interrupt bidirectional communications, logic & communication to other PIC's. Probably I'm abusing my poor PIC, and from all tasks, analog conversion should be the priority as the rest of the processess are based on my movement sensors, to stabilize movement.
    Is Amplifying all analog signals to 5v the best choice?
    Is OpAmp the best choice to amplify them?
    Really thx babies & guys.-
    PD: I changed from PIC18F4431 to PIC18F4553, for faster speed (12 MIPS [48 MHz/4]), more A/D inputs (13 pins) and better A/D resolution (12 bit)
    "Beethoven had his critics too, see if you can name 3 of them"
    Dec 2005
    Quote Originally Posted by RodSTAR View Post
    best choice?
    That's too subjective a criteria.
    You can maximize resolution by choosing Vref+ that is(are) slightly higher than the highest expected voltage(s) from your sensor(s). This would be an extension of Melanie's approach. For example, if the gyro never outputs more than 3V you could use 3V for Vref and power the thermistor circuit with 3V also. There's no additional switching.
    The op amp solution is straightforward, time-honored and easy to understand. It can also maximize resolution and operates in realtime (essentially) so there are no additional delays.
    Both increase noise sensitivity.
    You really need to be clear about what you want. If you want maximum sensitivity, 5V/4096=1.22mV per unit while 3V/4096=0.73mV per unit so the op amp gives you a little more sensitivity. The difference is proportionally greater with 10-bit ADC.
    Well, ultimately the question is "Can I afford to lose 1 Bit of resolution in exchange for speed"?
    If the answer is YES, then your worstcase scenario with a 10-Bit ADC is...
    5v Sensor = 1023 Bits FSD
    3.3v Sensor = 675 Bits FSD
    3.0v Sensor = 613 Bits FSD.
    ... and you don't have to do anything.
    If you can't live with that, then it looks like OP-AMPs could be your choice. That's a lot of extra components for one extra measly bit of accuracy...
    But you could of course run your PIC at 3.0v (the voltage of your lowest Sensor) and simply use divider Resistors for your 3.3 and 5.0v Sensor inputs.
    May 2007
    Smile
    Considering melanie's and dhouston, last suggestions, I think the simplest, cheapest, noise cleanest, circuit simplest and MIPS faster option is to just connect sensors directly to my MCU/PIC/CPU.. specifically considering this case in which my PIC has a 12 bit resolution A/D (4 times the resolution than 10 bit). I'm happy with the idea, will test it and I'll let you know how how it works! and I think I'll can live with it
    __
    PD: Just away from this, appart I will play with OpAmps, just to know how these toys work.
    RodSTAR
    Dec 2005
    Smile
    Actually, that was my first suggestion, as well.
    Wink
    Hi, Mel
    I think the main Problem in those Autopilots is the "Heading lock" feature ... One must ALSO measure very small Gyro variations for the Vehicle ( let's say UAV ... 10$ !!! ) to keep the perfect straight line.
    so, a maximum resolution must be kept for heading precision while the full signal range has to be measured for High "G" movements controlling ... and avoiding " non linear " ( ROFL ) - or unwanted - moves.
    Thermistor is just here for best temp compensation of Gyro and Accelmeter ...
    May be 8 Bits PICs, and generally Pīcs are not the best components for this kind of Games ...
    May 2007
    Wink
    Hi, Mel
    In fact my UAV board has a dsPIC33F(12bit A/D) and a PIC32 and a math coprocessor for sensors (and other more sensors), maths processing, GPS parsing, coordinates algorythms, and blah blah, in fact is a full AHRS. I just want to play from conceptual small to prototype big. Lucky I have no problems on C30 and C32, I'm on the digital side of the project, not on the electronics side, as you can see by the title of this thread. But i love electronics and I'm working to try to get inside it. The board comes ready to program. My this thread was oriented to the "conceptual small" version of it.
  1. 12f675 A/d Miseries
    By MARAD75 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2008, 03:16
  2. 12F675 A/D and GPIO sleep interrupt
    By macinug in forum mel PIC BASIC Pro
    Last Post: - 8th September 2008, 15:39
  3. Need advice on A/D
    By james in forum mel PIC BASIC Pro
    Last Post: - 24th August 2007, 20:30
  4. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 19:57
  5. 18F2525 A/D, Comparator and Vref modules
    By fbraun in forum mel PIC BASIC Pro
    Last Post: - 21st May 2005, 00:17
