different voltaje a/d sensors
Results 1 to 22 of 22
    Dec 2005
    I don't understand the problem. If you are using 5V to power the PIC, you can also use it for AVdd. You will get the full range of all 3 sensors, you will merely lose resolution on the 3.3V & 3.0V sensors. If you want to maximize resolution, use op amps setup for DC gain to promote the 3.0V & 3.3V sensors.
    I think he wants full resolution of the A/D converter at 3.3v as well as 5.0v.
    Darrell had a real nice 10 to 16 bit selectable over sample routine. It seems the sites.picbasic.net site is having some issues, so right now you can not download it from there. It was here: http://sites.picbasic.net/index.php?...d=70&pageid=27 and it was called DT_Analog.pbp
    By going to 11 bit over sampling, you would effectively get the resolution back for your 3.3v devices, and no extra hardware. It does slow your sampling time a tiny "bit" for the extra bit.
    Here is the speed
    http://www.scalerobotics.com
    May 2007
    As PIC is 5v I was thinking to transform electrically all sensors to ranges to 0-5v with a "magical IC" that outputs an analog voltaje (not digital) proportional to the input.
    For example if a 3,3v device (accelerometer, sensor) outputs 1,65v (50% of 3,3v), then this "magical IC" will recive 1,65v and output 2,5v (50% of 5v).- Aswell if in another channel or other IC configured to transform 0-3v to 0-5v (if sensor says 1,5v my PIC will receive 2,5v). Of course I think this IC should be circuited for matching the desired specific voltaje range
    Maybe those "magical" IC's are OpAmps, as dhouston (thx!) commented. Can OpAmps make that function?
    "Realtime" processing is critical, so multisampling solution suggested by scalerobotics (thx!)is definitely not an option to my application. Interesting for another app anyway.
    And to shrink voltaje as mackrackit suggested (thx!) it would limit "natural" analog resolution. I prefer to amplify a voltaje than shrinking it. And I hope an Operational Amplifier (OpAmp) does that.
    So: Can OpAmps make that function?
    Thank you very much for your attention !
    "Beethoven had his critics too, see if you can name 3 of them"
    Sounds good. Certainly a lot of options.
    96.8 millionths of a second can seem like an eternity.
    Dec 2005
    Quote Originally Posted by RodSTAR View Post
    See the Non-Inverting Amplifier in http://www.national.com/an/AN/AN-31.pdf.
    You should be able to do it with three Resistors and two additional PIC pins...
    R1 connects between Vdd and VRef+.
    R2 connects between VRef+ and Digital PICpinX.
    R3 connects between VRef+ and Digital PICpinY.
    For additional stability, I would connect a 100nF Capacitor between VRef+ and 0v.
    Vref- connects to 0v.
    PICpinX and PICpinY are any available PIC pins that you have spare, that have full I/O capability and when in INPUT mode DO NOT have an internal Weak Pull-Up enabled.
    When requiring 5v on Vref+, set PICpinX and PICpinY to INPUT. A Vref+ of 5v is provided via R1. R2 and R3 are effectively not in circuit.
    When requiring 3.3v on Vref+, set PICpinX to OUTPUT LOW and PICpinY to INPUT. Vref+ is the product of Resistor divider chain R1 and R2. R3 is effectively not in circuit.
    When requiring 3.0v on Vref, set PICpinX to INPUT and PICpinY to OUTPUT LOW. Vref+ is the product of Resistor divider chain R1 and R3. R2 is effectively not in circuit.
    Resistors should be 1% or better. For absolute precision, make R2 and R3 hi-stab multi-turn pots and calibrate for 3.3v and 3.0v with their respecive PICpinX or PICpinY pulled OUTPUT LOW.
    In software, remember when switching between different VRef's, allow a short settling time before performing a new ADC measurement.
    Simple... cheap...
    Simple... cheap...
    That is slick !!!
    Dec 2005
    I considered that but the OP seemed to be asking how to promote the 3.0V and 3.3V sensors so they are, in effect, 5V sensors. I don't think anything other than amplifying the signals accomplishes that.
    By changing ADCON1 on the fly (between AVdd & Vref+) you can simplify it further. Or, it can be simplified by using 3.3V for the thermistor circuit.
    However, it does assume that the OUTPUT LOW voltage is 0V which may not be the case. It may be as high as 0.6V @ 4.5Vdd.
    Actually you don't need to assume 0v. It can be 1v for all the divider Resistors care... choose the values for R2/R3 that will give you 3.3v/3.0v when that pin is LOW, if you assume 0.6v then you will be pretty close with a paper exercise. If it's a one-off build (or a product where a high degree of accuracy is required), the using Hi-Stab multi-turn pots and manually calibrating as I suggested is the way to go...
    Either way, it's just another suggestion thrown into the melting pot of ideas... another could be using an LM317 and using the PIC to switch-in different Resistor values for different voltages (depending on the current draw, that option could also power your Sensor as well as Vref+)... one could carry on throwing ideas around all night long...
  1. 12f675 A/d Miseries
    By MARAD75 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2008, 02:16
  2. 12F675 A/D and GPIO sleep interrupt
    By macinug in forum mel PIC BASIC Pro
    Last Post: - 8th September 2008, 14:39
  3. Need advice on A/D
    By james in forum mel PIC BASIC Pro
    Last Post: - 24th August 2007, 19:30
  4. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 18:57
  5. 18F2525 A/D, Comparator and Vref modules
    By fbraun in forum mel PIC BASIC Pro
    Last Post: - 20th May 2005, 23:17
