12F629 int clk
Results 1 to 4 of 4
Thread: 12F629 int clk
    Oct 2009
    Vancouver
    Default 12F629 int clk
    Hey hey,
    Can the internal clk on a 12F629 be output to a pin?
    I need to check the stability for driving a RF PLL
    thanks
    Welcome to the forum.
    The pin OSC2 if the configuration bits are set for it will output Fosc/4.
    Check the data sheet for all the sorted details
    Oct 2009
    Vancouver
    Hey thanks mackrackit
    Got the I2C to write to a PLL chip but works correctly only on the first write
    FM = $1D
    FL = $74
    C1 = $A0
    C0 = $40
    addr=$CA
    I2CWRITE SDA, SCL, addr, [C1,C0,FM,FL]
    Above works great
    FM = $1E
    FL = $3D
    C1 = $A0
    C0 = $40
    addr=$CA
    This second write sends erroneous coefficients to the PLL
    Any ideas?
    Cheers, John
    Can you explain exactly what you are trying to do and who or what you are doing it to?
  1. Instant Int and encoder (Elect. Gearing)
    Last Post: - 29th November 2009, 03:29
  2. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 16:10
  3. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  4. strange int behaviour
    By tom in forum mel PIC BASIC Pro
    Last Post: - 17th November 2005, 16:41
  5. Servo control with 12F629
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th June 2005, 00:34
