Greetings all, this forum has been a great source of info, so thanks!
I am doing the speed, miles thing as shown in the following code. This works great until I slow to around 9 mph, then the timer overflows. If I test for an overflow, I can either set the speed to 0 or I can add 524 ms to the time and assume one timer overflow. That now works great down to ~4 mph. Below that, another overflow happens and my time is once again inaccurate. 16f676 running at 4MHz. In the code below, I have the first overflow commented out (PIR1.0) . Any suggestions on keeping track of these overflows? Thanks, Scott
define LCD_DREG PORTC
define LCD_DBIT 0
define LCD_RSREG PORTC
define LCD_RSBIT 5
define LCD_EREG PORTC
Define LCD_EBIT 4
define LCD_BITS 4
define LCD_LINES 2
Define LCD_COMMANDUS 2000
Define LCD_DATAUS 50
Define OSCCAL_1K 1
        CMCON = 7               'Port A to digital
        ANSEL = 0
        TRISA = %00001100
        TRISC = %00000000
        OPTION_REG = %01000000  'rising edge interrupt
        PIE1 = %00000000        'enable tmr1 overflow int w/ bit0
        PIR1 = %00000000        'reset per interrupt flags
        INTCON = %10010000      'global enable...
        T1CON = %00000000       'timer1 reset
        eeprom 0,[0,0]          'mile count storage - low byte first
        eeprom 2,[0,0]          'pulse count storage
        pulses var word         'timer register value 8uS per pulse
        pulses = 0
        w var word              'miles value
        w = 0
        x var word              'pulse count value
        x = 0
        y var word              'mS value
        y = 0
        z var word              'mph value
        z = 0
        D var byte
        D = 0
        Pause 500               'wait for LCD to startup
 on interrupt goto myint
 intcon = $90
start:  Lcdout $fe, 1           'clear LCD
        lcdout $fe, $80
        lcdout "IntSPEED"
        LCDOUT $fe, $C0
        LCDOUT "Ver 1.0 "
        pause 2000
        read 0,w.byte0          'read stored mile value
        read 1,w.byte1
        read 2,x.byte0          'read stored pulse count
        read 3,x.byte1
        T1CON = %00110001       'start timer
        TMR1L = 0
        TMR1H = 0
 loop:  Lcdout $fe, 1
        lcdout $fe, $80
        lcdout #y,"  ",#z
        LCDOUT $fe, $C0
        lcdout #x," ",#w
        for D = 1 to 100
        pause 1
        next D
        Goto loop               'do it forever
        Disable
 myint: pulses.byte0 = TMR1L    'value of timer to pulses variable
        pulses.Byte1 = TMR1H
        TMR1L = 0               'start timer over
        TMR1H = 0
                                '.001 = 125 * .000008
        y = pulses / 125        'convert X 8uS pulses to mS
        'if PIR1.0 = 1 then      'slow speed issues
        '    y = y + 525         'timer overflow
        '    PIR1.0 = 0          '~9 mph
        '    endif
        z = 4900 / y            'convert ms to mph
        if y = 0 then z = 0     'eliminate 65535 speed at 0mS
        if PIR1.0 = 1 then      'timer overflow
            z = 0
            PIR1.0 = 0
        x = x + 1               'increment pulse count
        write 2,x.byte0
        write 3,x.byte1
        if x = 733 then         '733 revs per mile at 27.5 dia wheel
            w = w + 1           'increment odometer
            write 0,w.byte0
            write 1,w.byte1
            x = 0               'reset pulse counter
        intcon.1 = 0
        resume
        enable
