"Extending" timer1
Results 1 to 10 of 10
    Aug 2007
    Default "Extending" timer1
    Greetings all, this forum has been a great source of info, so thanks!
    I am doing the speed, miles thing as shown in the following code. This works great until I slow to around 9 mph, then the timer overflows. If I test for an overflow, I can either set the speed to 0 or I can add 524 ms to the time and assume one timer overflow. That now works great down to ~4 mph. Below that, another overflow happens and my time is once again inaccurate. 16f676 running at 4MHz. In the code below, I have the first overflow commented out (PIR1.0) . Any suggestions on keeping track of these overflows? Thanks, Scott
    define LCD_DREG PORTC
    define LCD_DBIT 0
    define LCD_RSREG PORTC
    define LCD_RSBIT 5
    define LCD_EREG PORTC
    Define LCD_EBIT 4
    define LCD_BITS 4
    define LCD_LINES 2
    Define LCD_COMMANDUS 2000
    Define LCD_DATAUS 50
    Define OSCCAL_1K 1
            CMCON = 7               'Port A to digital
            ANSEL = 0
            TRISA = %00001100
            TRISC = %00000000
            OPTION_REG = %01000000  'rising edge interrupt
            PIE1 = %00000000        'enable tmr1 overflow int w/ bit0
            PIR1 = %00000000        'reset per interrupt flags
            INTCON = %10010000      'global enable...
            T1CON = %00000000       'timer1 reset
            eeprom 0,[0,0]          'mile count storage - low byte first
            eeprom 2,[0,0]          'pulse count storage
            pulses var word         'timer register value 8uS per pulse
            pulses = 0
            w var word              'miles value
            w = 0
            x var word              'pulse count value
            x = 0
            y var word              'mS value
            y = 0
            z var word              'mph value
            z = 0
            D var byte
            D = 0
            Pause 500               'wait for LCD to startup
     on interrupt goto myint
     intcon = $90
    start:  Lcdout $fe, 1           'clear LCD
            lcdout $fe, $80
            lcdout "IntSPEED"
            LCDOUT $fe, $C0
            LCDOUT "Ver 1.0 "
            pause 2000
            read 0,w.byte0          'read stored mile value
            read 1,w.byte1
            read 2,x.byte0          'read stored pulse count
            read 3,x.byte1
            T1CON = %00110001       'start timer
            TMR1L = 0
            TMR1H = 0
     loop:  Lcdout $fe, 1
            lcdout $fe, $80
            lcdout #y,"  ",#z
            LCDOUT $fe, $C0
            lcdout #x," ",#w
            for D = 1 to 100
            pause 1
            next D
            Goto loop               'do it forever
            Disable
     myint: pulses.byte0 = TMR1L    'value of timer to pulses variable
            pulses.Byte1 = TMR1H
            TMR1L = 0               'start timer over
            TMR1H = 0
                                    '.001 = 125 * .000008
            y = pulses / 125        'convert X 8uS pulses to mS
            'if PIR1.0 = 1 then      'slow speed issues
            '    y = y + 525         'timer overflow
            '    PIR1.0 = 0          '~9 mph
            '    endif
            z = 4900 / y            'convert ms to mph
            if y = 0 then z = 0     'eliminate 65535 speed at 0mS
            if PIR1.0 = 1 then      'timer overflow
                z = 0
                PIR1.0 = 0
            x = x + 1               'increment pulse count
            write 2,x.byte0
            write 3,x.byte1
            if x = 733 then         '733 revs per mile at 27.5 dia wheel
                w = w + 1           'increment odometer
                write 0,w.byte0
                write 1,w.byte1
                x = 0               'reset pulse counter
            intcon.1 = 0
            resume
            enable
    May 2008
    Italy
    Use a variable that you will increment by 1 at each timer overflow. When needed the variable will tell you how many overflows occured during your timing.
    write 0,w.byte0
    write 1,w.byte1
    Remember that EEPROM has a life cycle of 10^6 write/erase cycles
    Al.
    Jul 2008
    TURKIYE-KONYA
    hi aratti ;
    it is not about this thread.
    do you have any idea , what will happen after 10^6 write/erase cycles.
    May 2008
    Italy
    Very likely they will loose reliability.
    Read this interesting document @: http://ww1.microchip.com/downloads/e...otes/00537.pdf
    Al.
    Aug 2007
    Aratti,
    I think I understand the concept, but where would I put the variable increment in my code example? In the main loop, or something in the interrupt routine? That is basically what I was doing with the y=y+545. There I was only able to keep track of one overflow. In my interrupt, I am actually working with the previous timer value, not the current running timer value.
    Thanks for the reminder on the EEPROM thing.
    Scott
    Mar 2006
    China
    Default more about EE-proms
    If you look at the microchip EE-prom lifetime test they have compared different brands.. some better and some worse. I bet there is some advertising involved in the numbers but some brands only guarantee 100k write cycles. 100k or a million makes a difference.
    May 2008
    Italy
    chips123
    Naturally in your interupt routine. Let assume you have a variable Tmr1Z (declared as Word) and you increment TMR1Z by 1 at each overflow then TMR1L & TMR1H and TMR1Z will give you a 32 bits count from which you could pullout a lot of information.
    Also y = y + 525 could be used but since y will overflow itself after 124 timer1 overflow is not very helpfull.
    Jumper
    One is ten times the other! 100K makes life even more difficult.
    For pic 16F676 this is what datasheet report:
    - 100,000 write FLASH endurance
    - 1,000,000 write EEPROM endurance
    - FLASH/Data EEPROM Retention: > 40 years
    Al.
    Aug 2007
    I thought about this some more and thought that I came to the conclusion that I should do it in the main loop. When I used the y=y+525 in the interrupt routine, it only worked for the first timer overflow. Since the interrupt only cycles through once and the timer continues to run even if an interrupt has not happened, I figured I would need to keep checking for the overflow in my main loop. Let me know what you think of this. I wil need to try it tonight. Thanks.
    May 2008
    Italy
    I had the impression it was an INTERRUPT ON OVERFLOW routine.
    Why don't you use Darrel Taylor instant interrupt, it is easy to use and works very well indeed!
    Visit Darrel site @ http://darreltaylor.com/DT_INTS-14/intro.html
    Al.
  1. Software PWM using Timer1
    By muqasim in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 12:49
  2. Help with TIMER1 + SLEEP
    By Yodoad in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 16:07
  3. Time Period of Timer1
    By arnol34 in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 01:31
  4. Timer1 and Interupt wierdness
    By mind in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2005, 02:24
  5. Use of Timer1 with 16F819
    By Barry Johnson in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 17:25
