I think you need to disable the TMR4 interrupts in Donebyte, instead of clearing the flag.
I'll try to run it here on a 4520.
No Timer4, but Timer2 should do the same thing for me.
OK, got it working here ...
You do need to disable T4 ints (last post).
And I haven't figured out why yet, but it was missing a bit in each byte, so I increased _bit_cntr to 9 and now it works.
I'll play with it some more and post the final results.
Here ya go ...
The 9-bit issue was due to flags not being cleared first before enabling.
I've changed it to put the bit periods in PR4 instead of TMR4, this eliminates the latencies without having to reload the timer.
Since I was using an 18F4520 (no TMR4), I made it so you can use any of the 8-bit timers that count up to PR?, TMR2, 4 or 6.
I've also changed several other things, so look carefully if you're trying to pick them out.
My debug method was sending the received byte out the USART, instead of PORTD.
HTH,Code:DEFINE OSC 40 DEFINE RX_TMR 4 ; can be 2, 4 or 6 DEFINE TMR_INT TMR4_INT ; int must match timer selection ;RCSTA = $90 ' Enable serial port & continuous receive ;TXSTA = $20 ' Enable transmit, BRGH = 0 ;SPBRG = 64 ' 9600 Baud @ 40MHz, 0.16% bit_cntr VAR BYTE BANK0 rcv_byte VAR BYTE BANK0 byteready VAR BYTE BANK0 rcv_buffer VAR BYTE BANK0 ;----------------------------------------------------------------------- INCLUDE "DT_INTS-18.bas" ; Base Interrupt System ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler INT0_INT, GetStart, ASM, yes INT_Handler TMR_INT, BitTimer, ASM, yes endm INT_CREATE ; Creates the interrupt processor ENDASM Goto OverInt '---[INT - interrupt handler]--------------------------------------------------- ASM #define TMR_VAL TMR#v(RX_TMR) #define TMR_CON T#v(RX_TMR)CON #define TMR_PR PR#v(RX_TMR) ENDASM ASM GetStart movlw 0x02 ; T? OFF, /16 prescale, no postscalers movwf TMR_CON movlw 0x61 ; 156uSec dly @ 40Mhz = 1.5 bit times movwf TMR_PR clrf TMR_VAL bsf TMR_CON,2 ; Turn timer on INT_ENABLE TMR_INT ; turn on the Timer INT movlw 0x08 ; load the bit counter movwf _bit_cntr INT_DISABLE INT0_INT ; shut off the INT0 interrupt INT_RETURN ENDASM ASM BitTimer movlw 0x41 ; load PR2 for 1 bit period movwf TMR_PR btfss PORTB,0 ; check status of portB.0 bcf STATUS,C ; move bit into carry btfsc PORTB,0 ; check status of portb.0 bsf STATUS,C ; move bit into carry rrcf _rcv_byte,f ; shift carry into rec'd byte decfsz _bit_cntr,f ; decrement the bit counter bra Donebit ; get out and wait for next int bra Donebyte ; got 8 bits Donebit INT_RETURN Donebyte movff _rcv_byte,_rcv_buffer ;TXwait ; btfss PIR1, TXIF ; bra TXwait ; movff _rcv_buffer, TXREG movff _rcv_buffer,PORTD ; this is a debug, just to see rec'd byte on LEDS bcf TMR_CON,2 INT_DISABLE TMR_INT INT_CLEAR INT0_INT INT_ENABLE INT0_INT ; turn on the INT0 interrupt for next byte INT_RETURN ENDASM OVERINT: TRISD = 0 PORTD = 0 TRISE = 0 INTCON2.6 = 0 ; int0 on falling edge PAUSE 100 @ INT_CLEAR INT0_INT @ INT_ENABLE INT0_INT WAITT: GOTO WAITT
Darrel,
Thanks a million! While I don't know for sure, I'd guess that your little program is the start of something that will be really useful to all those people who post "how can I receive bytes while....... with my 16Fxxx". Tomorrow, I'll work on the SEND side and the buffering.
Charles Linquist
Sure, no problem Charles,
Already done ...
Tmr_tx-18
http://www.picbasic.co.uk/forum/show...1&postcount=28
Or, at least it's a good start.
Charles,
Just for an additional example and reference, I posted a 9600 baud half-duplex example on PICLIST several years ago that uses Timer 2 and IOC. I also have a full-duplex demo and another half-duplex demo that uses Timer 0 that shows how to reload a free-running 8 bit timer.
Hope the examples help. Have a great day.
Regards, Mike
Code:;****************************************************************** ;* * ;* Filename: 12F683 Half-Duplex 9600 Demo.asm * ;* Author: Mike McLaren, K8LH (k8lh_at_arrl.net) * ;* Date: 02-Jun-05 (last revision 02-Dec-05) * ;* * ;* Half Duplex Bit-Banged 9600 Baud Serial I/O Demo * ;* (with 16-byte circular receive character buffer) * ;* * ;* ·Uses 12F683 INTOSC running at 8-MHz * ;* ·Bit rate error 0.16% plus or minus 1.0% for INTOSC * ;* ·Bit-banged 9600 baud serial I/O * ;* ·Half Duplex (should not TX and RX simultaneously) * ;* ·TMR2 interrupts at 104-usec intervals (every 208 * ;* instruction cycles) and IOC (interrupt on change) * ;* for RX start bit leading edge detection on RXPIN * ;* ·Circular 16-byte RX character buffer * ;* ·Inverted TX and RX signals (MAX232A or similar * ;* inverting RS-232 interface required) * ;* ·Relatively small - the ISR and the support routines * ;* Init232, Put232, and Get232 use 102 words of code * ;* space at locations 0004 through 0069 * ;* ·Worst case 23% ISR 'overhead' (24-usecs) when a * ;* complete RX character is added to the circular * ;* buffer once every 1.04-msecs while receiving * ;* * ;* MPLab: 7.21 (tabs=8) * ;* MPAsm: 4.02 * ;* * ;******************************************************************
