ASM help
Results 1 to 17 of 17
Thread: ASM help
    Sep 2005
    Campbell, CA
    I understand your improvement, and I realized that I hadn't considered latency, but at 40Mhz, it is only a few uSec.
    Even with a small timing error, it should get the first few bits right - but doesn't!
    Charles Linquist
    In Donebyte, before re-enabling the INT0 interrupt, it clears the Timer4 flag.
    INT0IF will still be set and you'll get a false start when there's no data.
          bcf  PIR3,3       ; clear the int flag
          bsf INTCON,4   ; turn on the INT0 interrupt for next byte
    And I think the 1-1/2 bit time is off.
    97 would be right if it were decimal, but it's hex.
    Try it with 0x61.
    Knowing you, this is probably part of a much bigger program with lots of variables ...
    You'll probably want to put the variables used in ASM into BANK0
             bit_cntr  VAR BYTE BANK0
             rcv_byte  VAR BYTE BANK0
             rcv_buffer   VAR BYTE BANK0
    There's really no need to stop timer4 when reloading since it's an 8-bit timer.
    But adding the reload value to TMR4 instead of just loading it will cancel out any latencies.
    Sep 2005
    Campbell, CA
    Unhappy
    Yes, this *WILL* be part of a much bigger program!
    I made some changes -
    I cleared INTCON.1 before I re-enabled it in the
    Donebyte routine
    Donebyte
          movff _rcv_byte,_rcv_buffer
          movff _rcv_buffer,PORTD  ; this is a debug, just to see rec'd byte on LEDS
          bcf INTCON,1
          INT_RETURN
    But that didn't help. It shouldn't have been set anyway, since I clear it
    after I shut off INT0 in the
    GetStart section.
    I changed the TMR4 reload value to 0x61
    I put the variables in BANK0
    I made the change recommend by Jerson to take one line out of the setb/clrb
    sequence.
    Still, when I hit ANY character, all the LEDs on PORTD light up (high).
    Something small still isn't right.
    Charles Linquist
    I think you need to disable the TMR4 interrupts in Donebyte, instead of clearing the flag.
    I'll try to run it here on a 4520.
    No Timer4, but Timer2 should do the same thing for me.
    OK, got it working here ...
    You do need to disable T4 ints (last post).
    And I haven't figured out why yet, but it was missing a bit in each byte, so I increased _bit_cntr to 9 and now it works.
    I'll play with it some more and post the final results.
    Here ya go ...
    The 9-bit issue was due to flags not being cleared first before enabling.
    I've changed it to put the bit periods in PR4 instead of TMR4, this eliminates the latencies without having to reload the timer.
    Since I was using an 18F4520 (no TMR4), I made it so you can use any of the 8-bit timers that count up to PR?, TMR2, 4 or 6.
    I've also changed several other things, so look carefully if you're trying to pick them out.
    My debug method was sending the received byte out the USART, instead of PORTD.
    DEFINE OSC 40
    DEFINE RX_TMR  4          ; can be 2, 4 or 6
    DEFINE TMR_INT TMR4_INT   ; int must match timer selection
    ;RCSTA = $90 ' Enable serial port & continuous receive
    ;TXSTA = $20 ' Enable transmit, BRGH = 0
    ;SPBRG = 64  ' 9600 Baud @ 40MHz, 0.16%
     byteready   VAR BYTE BANK0
            INCLUDE "DT_INTS-18.bas"         ; Base Interrupt System
                  INT_Handler    INT0_INT,   GetStart,   ASM,  yes
                  INT_Handler     TMR_INT,   BitTimer,   ASM,  yes
    Goto OverInt
    '---[INT - interrupt handler]---------------------------------------------------
    #define TMR_VAL TMR#v(RX_TMR)
    #define TMR_CON T#v(RX_TMR)CON
    #define TMR_PR  PR#v(RX_TMR)
    GetStart
          movlw 0x02             ; T? OFF, /16 prescale, no postscalers
          movwf TMR_CON
          movlw 0x61             ; 156uSec dly @ 40Mhz = 1.5 bit times
          movwf   TMR_PR
          clrf    TMR_VAL
          bsf     TMR_CON,2      ; Turn timer on
          INT_ENABLE  TMR_INT    ; turn on the Timer INT
          movlw   0x08           ; load the bit counter
          movwf   _bit_cntr
          INT_DISABLE INT0_INT   ; shut off the INT0 interrupt
          INT_RETURN
    BitTimer
          movlw 0x41             ; load PR2 for 1 bit period
          movwf TMR_PR
          btfss PORTB,0          ; check status of portB.0
          bcf   STATUS,C         ; move bit into carry
          btfsc PORTB,0          ; check status of portb.0
          bsf   STATUS,C         ; move bit into carry
          rrcf   _rcv_byte,f     ; shift carry into rec'd byte
          decfsz _bit_cntr,f     ; decrement the bit counter
          bra   Donebit          ; get out and wait for next int
          bra Donebyte           ; got 8  bits
    Donebit
          INT_RETURN
    Donebyte
    ;TXwait
    ;      btfss  PIR1, TXIF
    ;      bra  TXwait
    ;      movff _rcv_buffer, TXREG
          bcf  TMR_CON,2
          INT_DISABLE  TMR_INT
          INT_CLEAR    INT0_INT
          INT_ENABLE   INT0_INT      ; turn on the INT0 interrupt for next byte
          INT_RETURN
    OVERINT:
        TRISD = 0
        PORTD = 0
        TRISE = 0
        INTCON2.6 = 0            ; int0 on falling edge
        PAUSE 100
    @   INT_CLEAR  INT0_INT
    @   INT_ENABLE INT0_INT
    WAITT:
        GOTO WAITT
    HTH,
    Sep 2005
    Campbell, CA
    Darrel,
    Thanks a million! While I don't know for sure, I'd guess that your little program is the start of something that will be really useful to all those people who post "how can I receive bytes while....... with my 16Fxxx". Tomorrow, I'll work on the SEND side and the buffering.
    Charles Linquist
  1. PBP, ASM and LST files
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th January 2010, 14:43
  2. ASM or PBP First?
    By mackrackit in forum Off Topic
    Last Post: - 10th October 2009, 13:08
  3. Serial Output - for an ASM numb
    By scomi85 in forum Serial
    Last Post: - 1st March 2009, 11:13
  4. Problem using ASM instruction
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2008, 16:26
  5. Can an asm interrupt contain gosub to a picbasic routine?
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 21st April 2005, 20:49
