ASM help
Results 1 to 17 of 17
Thread: ASM help
    Sep 2005
    Campbell, CA
    Default ASM help
    I'm trying to re-create a hardware serial port with pure software. I need a non-blocking RECEIVE port because I need to add a 3rd port to my 8723.
    Most of the interrupt-driven routines I have seen have a very large processor overhead because they sample all the time and because they sample often so as to get the bit timing right.
    I'm trying an approach that uses INT0. It watches for the first falling edge of the START bit, then starts a TMR4 interrupt to time the rest of the bits. Using this approach should use zero processing power when a byte isn't coming in, and not too many cycles when one is. INT0 is turned on only to detect the falling edge of the START bit. TMR4 int is turned on only when receiving bits.
    The trouble is - the following code always returns 0xff whenever I send it a character. Can someone tell me what I'm doing wrong? RxD is coming through a MAX232 and is fed to PORTB.0
              T4CON = %00000110   ; T4 ON, /16 prescale, no postscalers
             INTCON = %11000000  ; Global Int enable, peripheral INT enable
             INTCON2 = %00000000
             PIE3.3 = 0 ;Turn off Int on tmr 4
             IPR3.3 =1           ; High priority for INT4
             bit_cntr  VAR BYTE
             rcv_byte  VAR BYTE
             byteready VAR BYTE
             rcv_buffer   VAR BYTE
            INCLUDE "DT_INTS-18.bas"         ; Base Interrupt System
                  INT_Handler    INT0_INT,   GetStart,   ASM,  no
                  INT_Handler    TMR4_INT,   BitTimer,   ASM,  no
    Goto OverInt
    GetStart
          bcf T4CON,2   ; Turn off Timer 4
          movlw 0x97   ; w /16 prescaler gives 156uSec dly @ 40Mhz = 1.5 bit times
          movwf TMR4
          bsf T4CON,2     ; Turn timer 4 on
          bsf  PIE3,3     ; turn on the Timer4 INT
          movlw 0x08      ; load the bit counter
          movwf _bit_cntr
          bcf INTCON,4   ; shut off the INT0 interrupt
          bcf  INTCON,1   ; clear INT0 int flag bit
          INT_RETURN
    BitTimer
          bcf T4CON,2     ; Turn Timer4 off
          movlw 0xBF      ; 104uSec   / 16, 40 Mhz  1 bit time
          movwf TMR4      ; load it
          bsf T4CON,2     ; Turn it back on
          btfss PORTB,0   ; check status of portB.0
          bcf   STATUS,C  ; move bit into carry
          btfsc PORTB,0   ; check status of portb.0
          bsf   STATUS,C   ; move bit into carry
          rrcf   _rcv_byte,f ; shift carry into rec'd byte
          decfsz _bit_cntr,f ; decrement the bit counter
          bra   Donebit      ; get out and wait for next int
          bra Donebyte       ; got 8  bits
    Donebit
          bcf  PIR3,3        ; clear the int flag
          bsf  PIE3,3        ; start the TMR4 int again
          INT_RETURN
    Donebyte
          movff _rcv_byte,_rcv_buffer
          movff _rcv_buffer,PORTD  ; this is a debug, just to see rec'd byte on LEDS
          bsf INTCON,4   ; turn on the INT0 interrupt for next byte
          INT_RETURN
    OVERINT:
        TRISD = 0
        PORTD = 0
        TRISE = 0
        INTCON.1 = 0
        PIE3.3 = 0
        PIR3.3 = 0
             PAUSE 100
    @    INT_ENABLE INT0_INT
    WAITT:
        GOTO WAITT
    Charles Linquist
    Bombay, India
    You need to consider the interrupt latency along with the bit time and adjust the timer accordingly. Look at the generated listing to know how much it is. Another improvement is here
    BitTimer
    Sep 2005
    Campbell, CA
    I understand your improvement, and I realized that I hadn't considered latency, but at 40Mhz, it is only a few uSec.
    Even with a small timing error, it should get the first few bits right - but doesn't!
    Charles Linquist
    In Donebyte, before re-enabling the INT0 interrupt, it clears the Timer4 flag.
    INT0IF will still be set and you'll get a false start when there's no data.
    And I think the 1-1/2 bit time is off.
    97 would be right if it were decimal, but it's hex.
    Try it with 0x61.
    Knowing you, this is probably part of a much bigger program with lots of variables ...
    You'll probably want to put the variables used in ASM into BANK0
             bit_cntr  VAR BYTE BANK0
             rcv_byte  VAR BYTE BANK0
             rcv_buffer   VAR BYTE BANK0
    There's really no need to stop timer4 when reloading since it's an 8-bit timer.
    But adding the reload value to TMR4 instead of just loading it will cancel out any latencies.
    <br>
    Sep 2005
    Campbell, CA
    Unhappy
    Yes, this *WILL* be part of a much bigger program!
    I made some changes -
    I cleared INTCON.1 before I re-enabled it in the
    Donebyte routine
    Donebyte
          bcf INTCON,1
          INT_RETURN
    But that didn't help. It shouldn't have been set anyway, since I clear it
    after I shut off INT0 in the
    GetStart section.
    I changed the TMR4 reload value to 0x61
    I put the variables in BANK0
    I made the change recommend by Jerson to take one line out of the setb/clrb
    sequence.
    Still, when I hit ANY character, all the LEDs on PORTD light up (high).
    Something small still isn't right.
    Charles Linquist
    I think you need to disable the TMR4 interrupts in Donebyte, instead of clearing the flag.
    I'll try to run it here on a 4520.
    No Timer4, but Timer2 should do the same thing for me.
    <br>
    OK, got it working here ...
    You do need to disable T4 ints (last post).
    And I haven't figured out why yet, but it was missing a bit in each byte, so I increased _bit_cntr to 9 and now it works.
    I'll play with it some more and post the final results.
    <br>
    Here ya go ...
    The 9-bit issue was due to flags not being cleared first before enabling.
    I've changed it to put the bit periods in PR4 instead of TMR4, this eliminates the latencies without having to reload the timer.
    Since I was using an 18F4520 (no TMR4), I made it so you can use any of the 8-bit timers that count up to PR?, TMR2, 4 or 6.
    I've also changed several other things, so look carefully if you're trying to pick them out.
    My debug method was sending the received byte out the USART, instead of PORTD.
    DEFINE OSC 40
    DEFINE RX_TMR  4          ; can be 2, 4 or 6
    DEFINE TMR_INT TMR4_INT   ; int must match timer selection
    ;RCSTA = $90 ' Enable serial port & continuous receive
    ;TXSTA = $20 ' Enable transmit, BRGH = 0
    ;SPBRG = 64  ' 9600 Baud @ 40MHz, 0.16%
     byteready   VAR BYTE BANK0
                  INT_Handler    INT0_INT,   GetStart,   ASM,  yes
                  INT_Handler     TMR_INT,   BitTimer,   ASM,  yes
    Goto OverInt
    #define TMR_VAL TMR#v(RX_TMR)
    #define TMR_CON T#v(RX_TMR)CON
    #define TMR_PR  PR#v(RX_TMR)
    GetStart
          movlw 0x02             ; T? OFF, /16 prescale, no postscalers
          movwf TMR_CON
          movlw 0x61             ; 156uSec dly @ 40Mhz = 1.5 bit times
          movwf   TMR_PR
          clrf    TMR_VAL
          bsf     TMR_CON,2      ; Turn timer on
          INT_ENABLE  TMR_INT    ; turn on the Timer INT
          movwf   _bit_cntr
          INT_DISABLE INT0_INT   ; shut off the INT0 interrupt
          INT_RETURN
    BitTimer
          movlw 0x41             ; load PR2 for 1 bit period
          movwf TMR_PR
    Donebit
          INT_RETURN
    Donebyte
    ;TXwait
    ;      btfss  PIR1, TXIF
    ;      bra  TXwait
    ;      movff _rcv_buffer, TXREG
          bcf  TMR_CON,2
          INT_DISABLE  TMR_INT
          INT_CLEAR    INT0_INT
          INT_ENABLE   INT0_INT      ; turn on the INT0 interrupt for next byte
          INT_RETURN
    OVERINT:
        TRISD = 0
        PORTD = 0
        TRISE = 0
        INTCON2.6 = 0            ; int0 on falling edge
        PAUSE 100
    @   INT_CLEAR  INT0_INT
    WAITT:
        GOTO WAITT
    HTH,
    Sep 2005
    Campbell, CA
    Darrel,
    Thanks a million! While I don't know for sure, I'd guess that your little program is the start of something that will be really useful to all those people who post "how can I receive bytes while....... with my 16Fxxx". Tomorrow, I'll work on the SEND side and the buffering.
    Charles Linquist
    Sure, no problem Charles,
    Tomorrow, I'll work on the SEND side ...
    Already done ...
    Tmr_tx-18
    http://www.picbasic.co.uk/forum/show...1&postcount=28
    Or, at least it's a good start.
    <br>
    Aug 2005
    Michigan, USA
    Charles,
    Just for an additional example and reference, I posted a 9600 baud half-duplex example on PICLIST several years ago that uses Timer 2 and IOC. I also have a full-duplex demo and another half-duplex demo that uses Timer 0 that shows how to reload a free-running 8 bit timer.
    Hope the examples help. Have a great day.
    Regards, Mike
    ;*  Filename: 12F683 Half-Duplex 9600 Demo.asm                    *
    ;*    Author: Mike McLaren, K8LH   (k8lh_at_arrl.net)             *
    ;*      Date: 02-Jun-05  (last revision 02-Dec-05)                *
    ;*   Half Duplex Bit-Banged 9600 Baud Serial I/O Demo             *
    ;*   (with 16-byte circular receive character buffer)             *
    ;*  ·Uses 12F683 INTOSC running at 8-MHz                          *
    ;*  ·Bit rate error 0.16% plus or minus 1.0% for INTOSC           *
    ;*  ·Bit-banged 9600 baud serial I/O                              *
    ;*    ·Half Duplex (should not TX and RX simultaneously)          *
    ;*    ·TMR2 interrupts at 104-usec intervals (every 208           *
    ;*     instruction cycles) and IOC (interrupt on change)          *
    ;*     for RX start bit leading edge detection on RXPIN           *
    ;*    ·Circular 16-byte RX character buffer                       *
    ;*    ·Inverted TX and RX signals (MAX232A or similar             *
    ;*     inverting RS-232 interface required)                       *
    ;*  ·Relatively small - the ISR and the support routines          *
    ;*   Init232, Put232, and Get232 use 102 words of code            *
    ;*   space at locations 0004 through 0069                         *
    ;*  ·Worst case 23% ISR 'overhead' (24-usecs) when a              *
    ;*   complete RX character is added to the circular               *
    ;*   buffer once every 1.04-msecs while receiving                 *
    ;*     MPLab: 7.21    (tabs=8)                                    *
    ;*     MPAsm: 4.02                                                *
    That is by far, the smallest program I've ever seen.
    <br>
    Aug 2005
    Michigan, USA
    Yeah, that didn't quite work out right Darrel (LOL). I'll go back and add the file...
    Regards, Mike
    Oops! Too late. I'll add it here (below). Sorry Gentlemen.
    Sep 2005
    Campbell, CA
    Thanks Mike,
    I thought that I was the first guy who dreamed up (what I think is) a relatively elegant way to save processor cycles. I should have known better!
    Charles Linquist
    Aug 2005
    Michigan, USA
    Thanks Mike,
    You're welcome Sir. And btw, just about everything I ever ended up patting myself on the back for inventing seems to have been done before too (LOL)...
    Regards, Mike
    But at least you have the satisfaction of INDEPENDANTLY coming up with the idea, which makes you as much the owner of that idea as anyone else who thought of it earlier or may do so later than you. Did Mr Bell or Mr Gray invent the telephone first? Personally I thought it was my kindergarden teacher with two cans of coffee and a length of string...
    Sep 2005
    Campbell, CA
    Thank you, Melanie!
    You know that I will always consider you the "Princess of the PICs"!
    Charles Linquist
  1. PBP, ASM and LST files
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th January 2010, 14:43
  2. ASM or PBP First?
    By mackrackit in forum Off Topic
    Last Post: - 10th October 2009, 13:08
  3. Serial Output - for an ASM numb
    By scomi85 in forum Serial
    Last Post: - 1st March 2009, 11:13
  4. Problem using ASM instruction
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2008, 16:26
  5. Can an asm interrupt contain gosub to a picbasic routine?
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 21st April 2005, 20:49
