Error[118]
Results 1 to 5 of 5
Thread: Error[118]
    Nov 2008
    Default Error[118]
    Hey,
    I'm done writing my program, but every time i try to compile it. It give the following error:
    Error[118] c:\pbp\picpro~1\ont\ontste~1.asm 154: Overwriting previous adress
    I have already located the error but i doesn't understand why he give the error.
    If i remove line 12 (org 0x00) or 97 (GOTO INITIAL) the problem is solved.
    But with the opcode org, i only say where i write my program away in the µC. So it doesn't matter that the goto instruction is also at 00. Or am i wrong?
    I have uploaded my program.
    Thanks at advance,
    Ward
    Nov 2008
    Hey,
    It's has noting to do with the original problem but i have found and solved another one. I say this so that you don't wonder why i did this if you are looking in the program.
    At line 371 i want to multiply by 10 and i did this by doing a rotate left 5 times, and that isn't a multiply by 10 but by 32.
    Now i didn't multiply the denominator, but i divided the divisor with 10.
    The new file is uploaded as well.
    If you found another mistake, please feel free to inform me.
    Ward
    Oct 2009
    Default 118 error
    I had the same 118 error when I got back to programming the other day. It's caused by a conflict in trying to write the config settings. The simple thing to do is to edit the INC file PBP directory and rem out the line beginning [i]__config
    Wink
    Hi, Lionheart
    I really do not understand why you use PicBasicPro fot such a program ...
    as it is fully asm Written ...
    Make it simple !!! you won't get errors such " 118 " ...
    BTW : Happy Birthday !!!
    Nov 2008
    Hey,
    Acetronics
    First of all thanks for wishing me a happy birthday.
    Originaly i wanted to write it in basic language. But i could not do wat i wanted. Because the time i can measure with Pulsin was to short. And in assembler i could costumize everything. And calculate the time to the nanosecond wich was also important.
    Scampy:
    I have inc my first line like you said from org0x00 to org 0x01 and the problem is gone. So if i understand correctly the problem was that the adress org 0x00 was preserved for the config settings then. Thanks for the info.
    Ward
  1. USBDemo, something to learn USB a little bit
    By mister_e in forum Code Examples
    Last Post: - 1st May 2014, 01:38
  2. Trying to migrate to 18F..
    By Glenn in forum General
    Last Post: - 10th February 2010, 00:25
  3. error in pbppic14.lib after re-installing xp
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 27th November 2009, 02:13
  4. Fail to compile, COD file missing
    By Jumper in forum mel PIC BASIC Pro
    Last Post: - 29th June 2009, 18:20
