Problem with SMS Project: Using 16F877A
Results 1 to 15 of 15
Threaded View
  1. #6
    Question
    I did the same process again with my original ph1 var byte[]13 only, results are the same. Also when I send another messege the previous number should be replaced at the location specified (Yes, it does enters to write the new number as led does toggles) , BUT its not happening as well. I also tried the following approach where I replaced all locations with "0" before writing the number :
    for a=0 to 12
    write a,"0" : pause 40
    write a,num[a] : toggle red : pause 700
    read a,ph1[a] : pause 40
    next a
    Still no luck.
    ___________________
    WHY things get boring when they work just fine?
  1. Problem displaying data from GPS module & using 16f877a
    Last Post: - 15th April 2010, 11:27
  2. Problem with SMS IO Controller
    By dario.costa in forum GSM
    Last Post: - 30th November 2009, 08:04
  3. 16F877A problem: "coupled" digital values
    By Lupo83 in forum General
    Last Post: - 4th December 2007, 13:46
  4. sending sms with 16f877A
    By anushka in forum General
    Last Post: - 18th January 2007, 12:00
  5. 16F877A serin problem with baud rate 19200
    By leemin in forum Serial
    Last Post: - 31st July 2005, 10:45
