Can anyone help a newcomer?
Results 1 to 19 of 19
    Oct 2009
    Why use another name for INTCON reg ???
    This was because I could not get the interrupts to work at first. I didn't know if there was a problem to use INTCON and so I changed it. I did the same with OPTION....it was just desperation I spent hours on this!
    The problem appeared to be that I was using MOVFW to write to INTCON. Once I change to BCF/BSF everything worked!
    Oct 2009
    I took your advice and increased the TX diode current. At the same time I tried a weak pull up on the output of the optical encoder. This seems to have done the trick and the interrupt is now being triggered.
    Thanks very much to you and Jerson for taking the time to help me.
    I will stay on the forum, it's a very useful resource.
    Danny
    Oct 2009
    Quote Originally Posted by scopit View Post
    Seems it wasn't a solution
    It is now in that frustrating state of intermittent
  1. Hlp - newcomer getting confused
    By chunk in forum General
    Last Post: - 23rd January 2006, 18:47
  2. 12F629 config help for newcomer
    Last Post: - 4th January 2004, 22:03
