Hi scopit
I can suggest you look at your TRISB settings. Have you set RB0 to input direction?
Hi Jerson,
Thanks for the welcome and the suggestion. RB0 is set to an input and I can connect the pin to 5V and trigger the interrupt routine manually. I have also tried enabling the internal pull ups via the option register, but no difference.
Here's my code which is not the complete progam yet. I have been testing step by step to make sure I have configured correctly. Forgive me if it not the best written code, this is my first serious program!
Any help is gratefully appreciated
Scopit
    list      p=16F84A             ; list directive to define processor
    #include <p16F84a.inc>         ; processor specific variable definitions
;       Set up constants
TIMER		EQU		0x01			; TMR0 register address
STATUS		EQU     0x03			; Status register address
PORTA		EQU     0x05			; Bank0 PORTA register address
PORTB		EQU     0x06			; Bank0 PORTB register address
INTREG		EQU		0x0B			; INTCON register address
OPTREG		EQU		0x81			; OPTION register address
TRISA		EQU     0x85			; Bank1 PORTA register address
TRISB		EQU     0x86			; Bank1 PORTB register address
; Set up constants
TARGET		EQU		0x59			; Target interval ideal value of 89Dec 59Hex
OLOOP1		EQU		0xE0			; Initial loop value for fine control 128
ILOOP1		EQU		0xE0			; Initial loop value for coarse control 27H
; Registers for program varialbles
OUTERL		EQU		0x10			; Fine control delay value register
INNERL		EQU		0x11			; Coarse control delay value register
STORE		EQU		0x12			; Temporary register
OLOOP		EQU		0x13			; Fine control delay count register
ILOOP		EQU		0x14			; Coarse control delay count register
WREG		EQU		0x16			; Stores W reg during interrupt
SREG		EQU		0x17			; Stores STATUS reg during interrupt
; Reset
		ORG		0x00			; Power up and reset code start
		GOTO	Setup			; Skip over interrupt routine
; Interrupt subroutine
		ORG		0x04
; Store STATUS and W Registers in temporary locations
		MOVWF	WREG
		SWAPF	STATUS,W		; Does not affect STATUS bits
		MOVWF	SREG
; Use PORTA bit 1 to signal interrupt
		BSF		PORTA,1
;Display
		MOVF	STORE,0			; Move STORE to W
		MOVWF	PORTB			; Display TMR0 value on PORTB1-7
; Clear Interrupts and flags
		CALL	Intclr			; Clear interrupts and reset prescalar values
; Retore STATUS and W Registers from temporary locations
		SWAPF	SREG,W			; Does not affect STATUS bits
		MOVWF	STATUS
		SWAPF	WREG,F
		SWAPF	WREG,W
		RETFIE					; Clears GIE bit in INTCON
Setup
; 		Set up Ports
		BSF			STATUS,5	; Switch to BANK1
		MOVLW	 	0x00		; Move 00000000 to W
		MOVWF		TRISA		; Set outputs RA0=PWM RA2=TMR0 RA3=Interrupt
		MOVLW	 	0x01		; Move 00000001 to W
		MOVWF		TRISB		; Set RB0 input, RB1--8 as outputs
		BSF			STATUS,5	; Switch to Bank1
; Set up option register
;		BSF			OPTREG,7	; Enable PORTB pull ups
		BSF			OPTREG,6	; Enable INTEDG, trigger RBO/INT on rising edge
		BCF			OPTREG,3	; Assign Prescaler to TMR0
		BSF			OPTREG,2	; Set prescalar to 1:256
		BSF			OPTREG,1	; Set prescalar to 1:256
		BSF			OPTREG,0	; Set prescalar to 1:256
		BCF			STATUS,5	; Switch to Bank0
; Clear ports and flag register
		CLRF		PORTA
		CLRF		PORTB
;		CLRF		FLAG
; Initialise loop values
		MOVLW		ILOOP1
		MOVWF		INNERL		; Initialise inner loop
		MOVLW		OLOOP1
		MOVWF		OUTERL		; Initialise outer loop
; Clear interrupts
		CALL		Intclr
		BCF			INTREG,5	; Disable TOIE in INTCON
		BSF			INTREG,4	; Enable INTE in INTCON
		BSF			INTREG,7	; Enable GIE in INTCON
;		Main Program
Main
		BSF			PORTA,0		; PWM high clcle
		CALL		Delay		; PWM high clcle
		BCF			PORTA,0		; PWM low cycle
		CALL		Delay		; PWM low cycle
		GOTO		Main		; PWM high until interrupt on RB0
;		Subroutines
Intclr
; Clear and enable interrupts
; Set bit 4 to enable INTE RB0/INT,
; Clear all other bits
		BCF			INTREG,0	; Clear RBO INT flag
		BCF			INTREG,1	; Clear RBO INT flag
		BCF			INTREG,2	; Clear TOIF flag
;Reset prescalar values in option register
Delay
; Delay subroutine to keep PWM pulse low
; Total number instructions (4+((Outer*5)=1)+(Inner*3)+1))
		MOVF		OUTERL,0	; Copy Outer loop value to W
		MOVWF		OLOOP		; Copy Outer loop value to loop count register
Outer
		MOVF		INNERL,0	; Copy Inner loop value to W
		MOVWF		ILOOP		; Copy Inner loop value to loop count register
Inner
		DECFSZ		ILOOP,1
 		GOTO		Inner
		DECFSZ		OLOOP,1
 		GOTO		Outer
; End of subroutines
        END                       ; directive 'end of program'
