LCD Blink
Results 1 to 6 of 6
Thread: LCD Blink
    Puerto Rico
    Question LCD Blink
    Hello i need help...
    how i avoid the blink using serout
    example:
    SerOut 1,N2400,[254,1]
    SerOut 1, N2400, [254, CDLine1,"EGT=",#EGT]
    Or
    SerOut 1, N2400, [254, CDLine1," "]
    Feb 2004
    Germany
    Default Re: LCD Blink
    jetpr
    I think you need to tell us a bit mor precise what actual problem is.
    I understand you are using a serial LCD.
    is the "blink" you are talking about a "blinking-block-cursor"
    What type of display are you using?
    regards
    Ralph
    Puerto Rico
    Question Blink LCD
    In set of using Clear the Screen with the LCD command ...
    Who i ken clear the Screen with out the LCD command for clear to avoid the blink screen..
    my problems is when you print to the LCD example...
    Start:
    Run=125
    SerOut 1, N2400, [254, LCDLine1,"Run=",#Run]
    Display Run=125
    but the problem is
    Run=12
    Display Run=125
    goto Stat
    the number 5 is from the one before and if a use the clear command then you si the screen blink..
    this ken be done by send spaces but i look blink and with the command for lcd...
    my ingles is not good so i dot now is a explain correct...
    I appreciation the help ..
    ayeeeeee. O.K.
    I'll try to make your life easier with some question and answer
    1. Do you want to avoid LCD blink when you refresh your display?
    This can be caused by the slow baudrate you're using or the delay between each LCD refresh.
    Usually when using a PAUSE of 100 ms between each LCD refresh is good.
    Try this
    start :
         SerOut 1, N2400, [254,1,"EGT=",#EGT] ' this line clear the LCD
                                              ' and display on the
                                              ' first line in one shot
         goto start
    2. Do you want to refresh only one part of your display. I mean only the section after "EGT=" ?
    In your case, try this one
    SerOut 1, N2400, [254,1,"EGT="]
    start :
         SerOut 1, N2400, [254,$84,"     "] ' this line clear 5 character
                                            ' after "EGT="
         SerOut 1, N2400, [254,$84,#EGT]    ' this line display your result
                                            ' right after "EGT="
         goto start
    I hope this is what you're looking for.
    I'm i right but you speak spanish? If yes, let us know, i think that some user can translate for you.
    WHO'S SPANISH HERE???
    P.S: a i see you just edit your post, perhaps the 2nd code example will work.
    Puerto Rico
    Talking LCD Blink
    Thans for you help i fix it
    Great to know that jetpr!
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. LCD will not start
