16F877 and 4094 please help
Results 1 to 19 of 19
    Sep 2009
    Default 16F877 and 4094 please help
    Hello friends
    I have manufactured this circuit with 16F877
    3 switches of entry that them portray the situation of entry in the 4094
    This code work good .my problem is always sees the last entry
    that I can see the all entries simultaneously be portrayed in the 4094
    INCLUDE "modedefs.bas"
    DEFINE SHIFT_PAUSEUS 100
            TRISB = %00000111
            alarm var word
            symbol clock=portc.4
            symbol data_pin=portc.2
            symbol strb=PORTc.3
            alarm=0
    start:
           IF PORTB.0=0 THEN
           alarm=%10000000
    	   IF PORTB.1=0 THEN
           alarm=01000000
    	   IF PORTB.2=0 THEN
           alarm=%00100000
           gosub print
           goto start
    print:
            ShiftOut data_pin,clock,0,[alarm]
            strb = 1  : PAUSEUS 100 :  STRB = 0
    Jul 2008
    TURKIYE-KONYA
    i didnt understand what you mean ;
    i think this will help you if i understood right.
            TRISB = %00000111
            alarm var byte
            flag   var byte
            symbol strb=PORTc.3
            alarm=0
            flag  = 0
    start:
           IF PORTB.0=0 THEN
                    alarm=%10000000
                    flag.0 = 1
                    flag.0 = 0
           IF PORTB.1=0 THEN
                    alarm=01000000
                    flag.1 = 1
                    flag.1 = 0
           IF PORTB.2=0 THEN
                   alarm=%00100000
                   flag.2 = 1
                   flag.2 = 0
           IF flag = 0 THEN alarm = 0
           gosub print
           goto start
    print:
    Bombay, India
            TRISB = %00000111
            alarm var byte
            symbol strb=PORTc.3
            alarm=0
    start:
           IF PORTB.0=0 THEN
    	    alarm = alarm + $80      ' add the bit
                alarm = alarm & $7F      ' remove the bit
           IF PORTB.1=0 THEN
    	    alarm=alarm + $40
                alarm = alarm & $BF      ' remove the bit
           IF PORTB.2=0 THEN
                alarm=alarm+$20
                alarm = alarm & $DF      ' remove the bit
           gosub print
           goto start
    print:
    Sep 2009
    Sorry for my English is not good
    I want he permanently remains turned on corresponding led (TOGGLE led)
    For each button that is activated
    May 2008
    Italy
    This will leave your last action ON.
            TRISB = %00000111
            alarm var BYTE
            Flag   var BYTE
            symbol strb=PORTc.3
            alarm=0
            Flag = 0
    start:
    Pause 10
           IF PORTB.0=0 THEN
           alarm=%10000000
    	Flag=1
    	   IF PORTB.1=0 THEN
           alarm=%01000000
    	Flag = 1
    	   IF PORTB.2=0 THEN
           alarm=%00100000
    	Flag = 1
    If Flag = 1 Then  gosub print
           goto start
    print:
            Flag = 0
    Al.
    Sep 2009
    Thank you very much for the answers
    But does not function the circuit,When I have in 3 inputs 0, (ΡΒ0=0,ΡΒ1=0,ΡΒ2=0)
    Do not turn on 3 led but always only 1
    This code only has shiftout....the leds are on your shiftin receive side...right?
    What you need to do is save your previous LED status. Currently every time you receive data from a button press it resets the other LED's so only 1 LED will be on.
    May 2008
    Italy
    To have also two or three leds on at the same time you have to add more code (in red):
            TRISB = %00000111
            alarm var BYTE
            Flag   var BYTE
            symbol strb=PORTc.3
            alarm=0
            Flag = 0
    start:
    Pause 10
    IF PORTB.0=0 THEN
    alarm=%10000000
    Flag=1
    IF PORTB.1=0 THEN
    alarm=%01000000
    Flag = 1
    IF PORTB.2=0 THEN
    alarm=%00100000
    Flag = 1
    IF PORTB.0=0  and PORTB.1 =0 THEN
    alarm=%11000000
    Flag=1
    IF PORTB.1=0  and PORTB.2 =0 THEN
    alarm=%01100000
    Flag=1
    IF PORTB.0=0  and PORTB.2 =0 THEN
    alarm=%10100000
    Flag=1
    IF PORTB.0=0  and PORTB.1 =0 AND PORTB.2 = 0 THEN
    alarm=%11100000
    Flag=1
           goto start
    print:
            Flag = 0
    Very likely you will need also a reset, in this case add the following code:
    IF PORTB.0=1  and PORTB.1 =1 AND PORTB.2 = 1 and alarm>0 THEN
    alarm=%00000000
    Flag=1
    You can also try the following code which is a lot shorter and should work as well.
            TRISB = %00000111
            Alarm   var BYTE
            Flag    var BYTE
            B0      var Byte
            symbol strb=PORTc.3
    alarm = 0
    Flag = 0
    B0 = 0
    start:
    Pause 10
    B0 = PortB & %00000111
    Alarm = (7 - B0) * 32
    If Alarm <> Flag then gosub Print
    goto start
    Print:
    Flag = Alarm
    Al.
    Sep 2009
    Yes it works irreproachably
    Thank you very much friend aratti
    Thank you very much all friends for the answers
    May 2008
    Italy
    Glad to hear that! You are welcome.
    Al.
    May 2014
    Default Re: 16F877 and 4094 please help
    I am inexperienced still in picbasic but I try
    Reading her user guide, and studying examples of code
    I noticed in this post the code from aratti, It is exactly what I need (thank you very much aratti)
    I used him as a basis, and I made changes so that him I adapt in my work
    Here I would want your help, so that I use also port C from the 16F876, so that I increase the inputs (push button) circuit in 16
    Thank you in advance
    regards
    Here it is the code and the circuit, that works perfect
    DEFINE OSC 10
    TRISA = %00000000
    TRISB = %11111111
    TRISC = %00000000
    ADCON1 = 7
    alarm var BYTE
    Flag   var BYTE
    bleg   var word
    B0      var word
    Symbol data_pin=PORTA.0
    Symbol clock=PORTA.1
    Symbol strb=PORTA.2
    Symbol oe=PORTA.3
    alarm=0
    Flag = 0
    B0 = 0
    bleg= 900
    portC = %00000000
    start:
    oe= 0:pause bleg
    B0 = PortB & %11111111
    Alarm = (0 + B0) * 1
    oe= 1:pause bleg
    goto start
    Print:
    ShiftOut data_pin,clock,1,[alarm]
    Flag = Alarm
    Sep 2009
    Hi Anatoli
    I am not guru in picbasic I will try to help you, with those who I know
    It tryed these changes
    DEFINE OSC 10
    TRISA = %00000000
    TRISB = %11111111
    TRISC = %11111111
    alarm var word
    Flag   var BYTE
    bleg   var word
    B0      var word
    C0      var word
    Symbol strb=PORTA.2
    Symbol oe=PORTA.3
    alarm=0
    Flag = 0
    B0 = 0
    C0 = 0
    bleg= 500
    portC = %00000000
    ADCON1 = 7
    start:
    oe= 0:pause bleg
    C0 = PortC & %11111111
    Alarm = (0 + C0) * 1  & Alarm = (0 + B0)
    oe= 1:pause bleg
    goto start
    Print:
    ShiftOut data_pin,clock,1,[alarm\8]
    Flag = Alarm
    May 2014
    Hi dovegroup
    I thank you for your help, him I tryed
    the second IC-4094 works rightly, but the first IC-4094 does not works any output
    Sep 2010
    Las Vegas, NV
    It looks like you're using Proteus and simulating the project. If so, and maybe not, you've assigned D9 to two chips which I'm assuming are the 4094. Change one or the other to something else and hook something up to the lower chip. Then see what you've got.
    May 2014
    Friends Dovegroup and AvionicsMaster1
    Connecting a logic analyzer in line CLOCK and DATA
    I discovered that the DATA that are directed to the IC-4094 are only 8bit, would not be supposed were 16bit
    8bit for the first IC and 8bit for the second IC
    See the snapshot from the analyzer
    Sep 2009
    Very rightly Aнатолий
    8bit for the first 4094 and 8bit for the second 4094
    I do not know to answer you how it will become this, I suppose that thus
    ShiftOut data_pin,clock,1,[alarm_1,alarm_2]
    May 2014
    I will try with this
    Thank you .Я благодарю товарища
    May 2014
    Товарища dovegroup
    Even if you are not guru in the picbasic as you report in initial your post
    Your help was very big, so that I complete my work
    See the changes that I made
    Alarma = (0 + C0) * 1
    Alarme = (0 + B0) * 1
    ShiftOut data_pin,clock,1,[Alarma,Alarme]
    Thank you very much
    Aнатолий (Anatoli)
    Sep 2009
    Anatoli good the knowledge guru my friend, but when doesn't exist appetite in order to you help ?
    I am cheerful that I even helped little So that you will complete your work
    привет товарищ Анатолий
    алексей или иным dovegroup
  1. 4094 Please Help
    By dovegroup in forum mel PIC BASIC Pro
    Last Post: - 10th September 2009, 12:11
