HElp Please.
Results 1 to 5 of 5
Thread: HElp Please.
    Angry 16F690 Outputs not support by PBP?...
    Im using a 16f690 pic and PBP2.46, and PBP 2.5
    I have many problems to use a simply code, example
    init:
    High PORTC.5
    High PORTC.4
    High PORTC.3
    High PORTC.6
    High PORTC.7
    High PORTB.7
    GOTO init
    This code dont work good. Many outputs donīt work fine at this code, outputs are a impredecible state.
    What are the problem...
    Any solution?...
    Last edited by joseluistajada; - 15th October 2009 at 19:29. Reason: more info about this problem
    joseluistajada, Have you set the TRIS register to determine which ports will be inputs and outputs?
    ANSEL = 0
    ANSELH = 0
    - OR -
    INCLUDE "ALLDIGITAL.pbp"
    Sep 2008
    Stockholm
    You dont need to set the pins to outputs when using "high" and "low".
    It's probably the analog part that is the problem just as darrel writes.
    PBP did not support this chip before the patch of 2.46.
    Go here to get the patch
    http://www.melabs.com/support/upgrade.htm#pbp
