USB HID Joystick for Dummies
Results 1 to 22 of 22
    Jun 2005
    Penang
    Default Re: USB HID Joystick for Dummies
    Hello all,
    Sorry.The above attached USBDesc have throttle & not Z axis.I have modified few of them but the result are the same.No response.One way around the Buttons should work,but in my case none of it is working.
    Jun 2005
    Penang
    hello all,
    Ok.We make it simple here.I added Z axis but in the gamepad configurator it shows the Z axis but not working...
    scumari's Avatar
    scumari Guest
    Ok , A 4 axis joystick with 12 buttons and a hat switch:
    PBP code-----------------------------------------------------
    Include "Js_hid_desc.bas" ' Include the HID descriptors
    'Include "modedefs.bas" ' Include serial modes
    DEFINE OSC 48
    DEFINE LOADER_USED 1
    DEFINE RESET_ORG 1100h ' For Microchip USB Bootloader
    DEFINE INTERRUPT_ORG 1108h ' For Microchip USB Bootloader 'LED var PORTC.0
    ' Define ADCIN parameters
    Define ADC_BITS 8 ' Set number of bits in result
    Define ADC_SAMPLEUS 100 ' Set sampling time in uS
    USBBufferSizeMax con 10 ' maximum buffer size
    USBBufferSizeTX con 10 ' input
    USBBufferSizeRX con 10 ' output
    ' the USB buffer...
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    temp var byte
    ' * Port configuration: *
    ' * PORTD.0-7 are digital inputs *
    ' * AN0,AN5 active as analog inputs *
    PORTA = 0
    PORTB = 0
    PORTC = 0
    PORTD = 0
    PORTE = 0
    TRISA = %11111111
    TRISB = %11111111
    TRISC = %11111111
    TRISD = %11111111
    TRISE = %11111111
    ADCON1 = %00001001
    ' * main program loop - remember, you must keep the USB *
    ' * connection alive with a call to USBService every couple *
    ' * of milliseconds or so... *
    USBInit ' initialise USB...
    ProgramStart:
    ' gosub DoUSBIn
    ADCIN 0,USBBuffer[0]
    ADCIN 1,USBBuffer[1]
    ADCIN 2,USBBuffer[2]
    ADCIN 3,USBBuffer[3]
    USBService ' keep connection alive
    temp = 255-PORTD
    USBBuffer.0(32) = PORTD.0
    USBBuffer.0(33) = PORTD.1
    USBBuffer.0(34) = PORTD.2
    USBBuffer.0(35) = PORTD.3
    USBBuffer.0(36) = temp.4
    USBBuffer.0(37) = temp.5
    USBBuffer.0(38) = temp.6
    USBBuffer.0(39) = temp.7
    temp = 255-PORTB
    USBBuffer.0(40) = temp.0
    USBBuffer.0(41) = temp.1
    USBBuffer.0(42) = temp.2
    USBBuffer.0(43) = temp.3
    USBBuffer.0(44) = temp.4
    USBBuffer.0(45) = temp.5
    USBBuffer.0(46) = temp.6
    USBBuffer.0(47) = temp.7
    DoUSBOut1:
    USBBufferCount = USBBufferSizeTX ' TX buffer size
    USBOut 1, USBBuffer, USBBufferCount, DoUSBOut2 ' if bus available, transmit data
    DoUSBOut2:
    GoTo ProgramStart
    DISCRIPTOR code----------------------------------------------------------------
    ReportDescriptor1
    RETLW 0x05
    RETLW 0x01 ; USAGE_PAGE (Generic Desktop)
    RETLW 0x09
    RETLW 0x04 ; USAGE (Joystick)
    RETLW 0xa1
    RETLW 0x01 ; COLLECTION (Application)
    RETLW 0x05
    RETLW 0x09
    RETLW 0xa1
    RETLW 0x00 ; COLLECTION (Physical)
    RETLW 0x09
    RETLW 0x30 ; USAGE (X)
    RETLW 0x09
    RETLW 0x31 ; USAGE (Y)
    RETLW 0x09
    RETLW 0x32 ; USAGE (Z)
    RETLW 0x09
    RETLW 0x33 ; USAGE (Rx)
    RETLW 0x75
    RETLW 0x08 ; REPORT_SIZE (8)
    RETLW 0x95
    RETLW 0x04 ; REPORT_COUNT (4)
    RETLW 0x35
    RETLW 0x00 ; PHYSICAL_MINIMUM (0)
    RETLW 0x46
    RETLW 0xff
    RETLW 0x00 ; PHYSICAL_MAXIMUM (255)
    RETLW 0x15
    RETLW 0x00 ; LOGICAL_MINIMUM (0)
    RETLW 0x26
    RETLW 0xff
    RETLW 0x00 ; LOGICAL_MAXIMUM (255)
    RETLW 0x81
    RETLW 0x02 ; INPUT (DataVarAbs)
    RETLW 0xc0 ; END_COLLECTION
    ; ------------ Hat Switches -------------------
    RETLW 0x09
    RETLW 0x39 ; Usage (Hat Sw)
    RETLW 0x15
    RETLW 0x00 ; Log Min (0)
    RETLW 0x25
    RETLW 0x03 ; Log Max (3)
    RETLW 0x35
    RETLW 0x00 ; Phy Min (0)
    RETLW 0x46
    RETLW 0x0e
    RETLW 0x01 ; Phy Max (270)
    RETLW 0x65
    RETLW 0x14 ; Unit (Eng Rot : Ang Pos)
    RETLW 0x75
    RETLW 0x04 ; Report Size (4)
    RETLW 0x95
    RETLW 0x01 ; Report Count (1)
    RETLW 0x81
    RETLW 0x02 ; Input (Data, Variable, Absolute)
    ; ------------ Buttons ------------------------
    RETLW 0x05
    RETLW 0x09 ; USAGE_PAGE (Button)
    RETLW 0x19
    RETLW 0x01 ; USAGE_MINIMUM (Button 1)
    RETLW 0x29
    RETLW 0x0c ; USAGE_MAXIMUM (Button 12)
    RETLW 0x15
    RETLW 0x25
    RETLW 0x01 ; LOGICAL_MAXIMUM (1)
    RETLW 0x45
    RETLW 0x00 ; PHYSICAL_MAXIMUM (0)
    RETLW 0x55
    RETLW 0x00 ; UNIT_EXPONENT (0)
    RETLW 0x75
    RETLW 0x01 ; REPORT_SIZE (1)
    RETLW 0x95
    RETLW 0x0c ; REPORT_COUNT (12)
    RETLW 0x81
    RETLW 0x02 ; INPUT (Data Var Abs)
    EndReportDescriptor1
    Now a 8 axis joystick with 8 buttons:
    PBP Code-----------------------------------
    Include "Th_hid_desc.bas" ' Include the HID descriptors
    DEFINE OSC 48
    'Define LCD_DREG PORTB ' LCD data pin port
    'Define LCD_DBIT 0 ' LCD data pin bit
    'Define LCD_RSREG PORTC ' LCD register select pin port
    'Define LCD_RSBIT 6 ' LCD register select pin bit
    'Define LCD_EREG PORTC ' LCD enable pin port
    'Define LCD_EBIT 7 ' LCD enable pin bit
    'Define LCD_BITS 4 ' LCD number of data bits
    'Define LCD_LINES 2 ' LCD number of lines
    'define HSER_RCSTA 090h
    'define HSER_TXSTA 0A4h
    'define HSER_BAUD 115200
    'define HSER_CLROERR
    ' the USB buffer...
    temp var byte
    PORTA = 0
    PORTB = 0
    PORTC = 0
    PORTD = 0
    PORTE = 0
    TRISA = %11111111
    TRISB = %11111111
    TRISC = %11111111
    TRISD = %11111111
    TRISE = %11111111
    ADCON1 = %00001001
    ProgramStart:
    'gosub DoUSBIn
    USBService
    ADCIN 4,USBBuffer[4]
    ADCIN 5,USBBuffer[5]
    GoSub DoUSBOut ' keep connection alive
    ADCIN 6,USBBuffer[6]
    ADCIN 7,USBBuffer[7]
    temp = 255-PORTD
    USBBuffer.0(64) = temp.4
    USBBuffer.0(65) = temp.5
    USBBuffer.0(66) = temp.6
    USBBuffer.0(67) = temp.7
    temp = 255-PORTB
    USBBuffer.0(68) = temp.0
    USBBuffer.0(69) = temp.1
    USBBuffer.0(70) = temp.2
    USBBuffer.0(71) = temp.3
    USBBuffer.0(72) = temp.4
    USBBuffer.0(73) = temp.5
    USBBuffer.0(74) = temp.6
    USBBuffer.0(75) = temp.7
    'GoSub DoUSBOut
    DoUSBOut2:
    GoTo ProgramStart
    ReportDescriptor1
    RETLW 0x05
    RETLW 0x09
    RETLW 0xa1
    RETLW 0x05
    RETLW 0x09
    RETLW 0xa1
    RETLW 0x09
    RETLW 0x09
    RETLW 0x09
    RETLW 0x09
    RETLW 0x09
    RETLW 0x34 ; USAGE (Ry)
    RETLW 0x09
    RETLW 0x35 ; USAGE (Rz)
    RETLW 0x09
    RETLW 0x36 ; USAGE (Ry)
    RETLW 0x09
    RETLW 0x37 ; USAGE (Rz)
    RETLW 0x75
    RETLW 0x95
    RETLW 0x08 ; REPORT_COUNT (8)
    RETLW 0x35
    RETLW 0x46
    RETLW 0xff
    RETLW 0x15
    RETLW 0x26
    RETLW 0xff
    RETLW 0x81
    RETLW 0x05
    RETLW 0x19
    RETLW 0x29
    RETLW 0x10 ; USAGE_MAXIMUM (Button 16)
    RETLW 0x15
    RETLW 0x25
    RETLW 0x45
    RETLW 0x75
    RETLW 0x95
    RETLW 0x10 ; REPORT_COUNT (16)
    RETLW 0x81
    They both work for FSX and X-Plane.
    See http://www.scumari.nl
    Have fun!
  1. USB hid maker help please.
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2013, 15:49
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  3. USB MSD with HID code ?
    By Chris Barron in forum USB
    Last Post: - 11th November 2009, 18:33
  4. i cant get 18f2550 work as HID
    By Ahmadabuomar in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 17:39
  5. Replies: 0
    Last Post: - 6th March 2009, 08:52
