I am confuse
Results 1 to 20 of 20
Thread: I am confuse
    Wink
    Hi, Mel
    my prehistorics datings ( 14 Carbide ...) are V2.21 ...
    mainloop: ADCON0.2 = 1		' Start Conversion
    notdone: Pause 5
    	If ADCON0.2 = 1 Then notdone	' Wait for low on bit-2 of ADCON0, conversion finished
    	adval = ADRESH		' Move high byte of result to adval
    of course it's impossible you knew it, may be your grand'dad ...
    I suspect " Pause 5 " here for 10,000 microns handcarved silicium "1650" processor ( PIC's ancester )...
    Aug 2009
    Red face I am back...
    Well after reading all of your posts and did some research on the 16f88 datasheet I applied some changes to my own program that looks it has improved. With all channels 0 to 3 straight to ground I got channels 2 and 3 to 0 and channels 0 and 1 to some value of 14. I am adding the program listing for your evaluation. Thank you in advance.
    @ __config _CONFIG1, _INTRC_IO & _WDT_ON & _LVP_OFF & _CP_OFF
    INCLUDE "modedefs.bas"
    ANSEL = %00001111 'set RA0-RA3 as analog inputs
    ADCON1 = %10000000 'Right Justifies 10-bit value
    OSCCON = $60 'Sets the internal oscillator to 4 Mhz
    CMCON = 7 'Comparators off
    DEFINE ADC_BITS 10 ' Sets the number of bits in the result to 10
    ti var byte
    ti = 50 '20 MILLISECONDS DELAY'
    A VAR word
    B VAR word
    C VAR word
    D VAR word
    TRISA = %00001111
    TRISB = 0 'TURN PORT B as outputs but RB1 WHEN USE ICD FOR COMMUNICATION
    '* * * * * MAIN PROGRAM START HERE * * * * * * * *
    PAUSE 1000
    Serout PORTB.1, 0, [254,1]
    Serout PORTB.1, 0, [254,2]
    PAUSE 20
    READSENSORS:
    ADCON0 = %00000001 'Turn ON CHAN 0
    GOSUB ADCON
    A.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    SEROUT PORTB.1 , 0, ["Ch 0= ",# A.LOWBYTE]
    pause 20
    ADCON0 = %00001001 'Turn ON CHAN 1
    GOSUB ADCON
    B.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    SEROUT PORTB.1 , 0, [" Ch 1= ",# B.LOWBYTE]
    PAUSE 20
    SEROUT PORTB.1,0,[$FE,$C0]
    ADCON0 = %00010001 'Turn ON CHAN 2
    GOSUB ADCON
    C.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    SEROUT PORTB.1 , 0, ["Ch 2= ",# C.LOWBYTE]
    PAUSE 20
    ADCON0 = %00011001 'Turn ON CHAN 3
    GOSUB ADCON
    D.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    SEROUT PORTB.1 , 0, [" Ch 3= ",# D.LOWBYTE]
    PAUSE 1000
    GOTO READSENSORS ' PROVISIONAL LOOP TO CHECK THE A/D CONVERTION.
    '* * * * * * * * * SELECTING THE MOTOR MOVEMENT * * * * * * * *
    IF A =0 and D =0 or C =0 and b =0 THEN GOTO READSENSORS 'IT IS DARK
    IF ABS (A-D)<10 OR ABS (B-C)<10 THEN GOTO READSENSORS 'IT IS ALIGNED
    If (B>D) OR (A>C) Then gosub Front
    IF (A>B) OR (C>D) THEN GOsub Left
    IF (C>A) OR (D>B) THEN GOsub Back
    IF (D>C) OR (B>A) THEN GOsub Right
    GOTO READSENSORS 'STAY FOR EVER LOOPING
    '* * * * * * * * * MOTOR'S MOVEMENTS SUBRUTINES * * * * * * * *
    Front:
    Serout PORTA.6, 0, ["FRONT ",# ABS (B-D)," ",# ABS (A-C)]
    SEROUT PORTA.6, 0, [$FE,$C0]
    PORTB = 1 'GOING FRONT
    PAUSE TI
    PORTB = 2
    PAUSE TI
    PORTB = 4
    PAUSE TI
    PORTB = 8
    PAUSE TI
    LEFT:
    Serout PORTA.6, 0, ["LEFT ",# ABS (a-b)," ",# ABS (C-D)]
    PORTB = 128 'GOING LEFT
    PAUSE TI
    PORTB = 64
    PAUSE TI
    PORTB = 32
    PAUSE TI
    PORTB = 16
    PAUSE TI
    Back:
    Serout PORTA.6, 0, ["BACK ",# ABS(C-A)," ",# ABS(D-B)]
    PORTB = 8 'GOING BACK
    PAUSE TI
    PORTB = 4
    PAUSE TI
    PORTB = 2
    PAUSE TI
    PORTB = 1
    PAUSE TI
    RIGHT:
    Serout PORTA.6, 0, ["RIGHT ",# ABS(D-C)," ",# ABS(B-A)]
    PORTB = 16 'GOING RIGHT
    PAUSE TI
    PORTB = 32
    PAUSE TI
    PORTB = 64
    PAUSE TI
    PORTB = 128
    PAUSE TI
    ADCON:
    ADCON1 = %10000000 'SET FOR 10 BITS
    ADCON0.2 = 1 'IT'S ONE TILL IT READS
    WHILE ADCON0.2 = 1 : WEND
    I am probably missing something but give this a shot.
    ti var byte
    A VAR word
    B VAR word
    C VAR word
    D VAR word
    TRISA = %00001111
    PAUSE 1000
    PAUSE 20
    READSENSORS:
    GOSUB ADCON
    pause 20
    GOSUB ADCON
    PAUSE 20
    GOSUB ADCON
    PAUSE 20
    GOSUB ADCON
    PAUSE 1000
    ADCON:
    This is what I am basing the sequence on. From the data sheet.
    1. Configure the A/D module:
    • Configure analog/digital I/O (ANSEL)
    • Configure voltage reference (ADCON1)
    • Select A/D input channel (ADCON0)
    • Select A/D conversion clock (ADCON0)
    • Turn on A/D module (ADCON0)
    I am pretty sure this sequence needs to be followed. I am not at the shop so I can not test your code now.
    Wink
    Hi, Dave and Tim
    I had a look to the TEST section of this program ... It gave that, with a " classic " PBP use. :
    'Config
    @	__CONFIG    _CONFIG1, _CP_OFF & _CCP1_RB3 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_ON & _PWRTE_ON & _WDT_ON & _INTRC_IO
    @ 	__CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
    '@ __config _CONFIG1, _INTRC_IO & _WDT_ON & _LVP_OFF & _CP_OFF
    'ADCON1 = %10000000 'Right Justifies 10-bit value
    'OSCCON = $60 'Sets the internal oscillator to 4 Mhz
    OSCCON 	= %01101110 'Internal RC w/ I/Os
    INTCON	= 0
    PIE1	= 0
    PIE2	= 0
    CVRCON 	= 0
    ti var byte
    A VAR word
    B VAR word
    C VAR word
    D VAR word
    _A CON 0
    _B CON 1
    _C CON 2
    _D CON 3
    TRISA = %00001111
    PAUSE 1000
    PAUSE 20
    READSENSORS:
    'ADCON0 = %00000001 'Turn ON CHAN 0
    'GOSUB ADCON
    ADCIN _A, A
    'A.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    pause 20
    'ADCON0 = %00001001 'Turn ON CHAN 1
    'GOSUB ADCON
    ADCIN _B, B
    'B.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    PAUSE 20
    'ADCON0 = %00010001 'Turn ON CHAN 2
    'GOSUB ADCON
    ADCIN _C, C
    'C.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    PAUSE 20
    'ADCON0 = %00011001 'Turn ON CHAN 3
    'GOSUB ADCON
    ADCIN _D, D
    'D.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    PAUSE 1000
    I just commented out original lines for comparison ...
    Hope it Helps
    Aug 2009
    Default Problem solved.
    I did the two editing of my program as Acetronics and as Mackrackit subjected. I ran both versions and ran with the same faulty results. I can’t understood how three persons could be wrong so I started again a check of my hardware. I found the problem on the breadboard. At the two power lines that runs on the outside of the board (-,+) the + line had 50 ohms! from one end to the other. I found a fault connection and restored it with a new line, problem goes. Now every input goes to zero. I want to thanks all of you including Melanie. Every time I come across an obstacle there is a reason to learn. Thanks.
    COOL!!!
    At least now you have a couple different ways to read the ADC.
    Have FUN!!!
    Aug 2009
    Default I had fun.
    Thank you. Yes I had a lot of fun with every project. I had to unassembled the breadboard and run a soldered copper line under all around it to ensure a good contact. That’s part of the fun also. Thanks.
  1. Replies: 288
    Last Post: - 25th August 2008, 16:53
