I think this chip has the comparators off on reset. I need to double check.
Thinking more along the lines of not reading both the high and low bytes of the 10 bit setup might be the problem???
Hi, Dave
you're right ... I never trust in defaults ... ( overhead, yes ... but sleeping nights ...)
what about this one :
Code:TRISA = %00001111RA5/MCLR/VPP bit 5 ST Input, Master Clear (Reset) or programming voltage input....I am using RA5 as my communication out to the LCD
Alan,
That would make the display act funny![]()
Well, first I did was to change the out pin to the LCD (Sorry I was using RA6 not RA5) to PortB.1 as for the test only. Second, I changed ADC to 8 bits and it went to zero but refuse to read any change voltage so I set it to back to 10. I wonder how can I set the AD comparators off using ADCON0. I read the 16F88 spec sheet page 114 and I don’t find a way to turn those comparators off. Please advice.
Worth reading.
I picked up the below method of reading the ADC here
http://www.rentron.com/PICX2.htm
I like it much better than ADCIN.
The below code is an example for reading ADC channel 0. Look at the example on the above link to add other channels.
It looks like a lot of stuff to do to read the ADC, pretty much what ADCIN does behind the scenes. This way you have control.
The "READ_AD" part is only needed once no matter how many channels you are reading (reusable).
Use your LCD or SERIAL to see what is happening. I have this running at 2400 baud. Works OK with the internal OSC for testing.
Code:[color=#000000] '16F88 ADC TEST FOR CHANNEL 0 DEFINE OSC 4 OSCCON = %01100000 @ __config _CONFIG1, _INTRC_IO & _WDT_OFF & _LVP_OFF & _MCLR_OFF &_CP_OFF ANSEL = %00001111 TRISA = %11111111 CHAN0 VAR WORD 'VAR TO HOLD ADC0 READING START: HIGH PORTB.3 'HEART BEAT PAUSE 250 LOW PORTB.3 PAUSE 250 'BELOW WILL SHOW WHAT THE ADRESH AND ADRESL REGISTER HOLDS SEROUT2 PORTB.2, 16780, ["ADRESH ",DEC ADRESH," ADRESL ",DEC ADRESL,$a,$d] PAUSE 50 'BELOW SHOWS THE 10 BIT READING OF ADC0 IN VAR CHAN0 SEROUT2 PORTB.2, 16780, ["CHAN0 ",DEC CHAN0,$a,$d] GOSUB ADC_0 'STARTS THE READING OF ADC CHANNEL 0 GOTO START ADC_0: 'READ AN0 ADCON1 = %10000000 'SET FOR 10 BIT ADCON0 = %00000001 'TURNS ADC ON GOSUB READ_AD CHAN0.HighByte = ADRESH 'PLACES THE HIGH AND LOW BYTE CHAN0.LowByte = ADRESL 'INTO VAR CHAN0 RETURN READ_AD: 'DOES THE ADC CONVERSION PAUSE 50 ADCON0.2 = 1 PAUSE 50 RETURN
You can actually improve on that Dave...
Instead of...
ADCON0.2=1
PAUSE 50
... which makes the assumption that your ADC reading will complete in 50mS... well - suppose it didn't? And suppose it only took only 50uS then you've wasted a shed load of time!
So, rather than a hit or miss approach, nail it properly...
ADCON0.2=1
WHILE ADCON0.2=1:WEND
To find out why I've done this, read the Datasheet description for pin ADCON0.2
