I am confuse
Results 1 to 20 of 20
Thread: I am confuse
    Aug 2009
    Red face I am confuse
    Hi, I am trying to use the 16f88 ability for read analog voltages. I need to use analog inputs RA0-RA3. My initial settings are as follows:
    ANSEL = %00001111 'set RA0-RA3 as analog inputs
    ADCON1 = %10000000 'Right Justifies 10-bit value
    OSCCON = $60 'Sets the internal oscillator to 4 Mhz
    DEFINE ADC_BITS 10 ' Sets the number of bits in the result to 10
    ti var byte
    ti = 50 '50 MILLISECONDS DELAY'
    A var word ‘ A,B,C and D as variables
    B var word
    C var word
    D var word
    TRISA = %00001111
    TRISB = 0 ‘Turn PORT B as outputs
    I am using RA5 as my communication out to the LCD. (Internal clock). I am using also the 8 pins Portb for controlling two steps motors. Problem here is that if I ground the input pins (just for testing) I should get zero voltages and I don’t. I am using a 1K resistor to ground. For sure I am missing something here. Please advice.
    With out seeing your code try setting the ADC for 8 bits and see what happens.
    Wink
    Set comparators OFF ...
    ADCON0 = ?
    I think this chip has the comparators off on reset. I need to double check.
    Thinking more along the lines of not reading both the high and low bytes of the 10 bit setup might be the problem???
    Wink
    Hi, Dave
    you're right ... I never trust in defaults ... ( overhead, yes ... but sleeping nights ...)
    what about this one :
    TRISA = %00001111
    RA5/MCLR/VPP bit 5 ST Input, Master Clear (Reset) or programming voltage input.
    Alan,
    That would make the display act funny
  1. Replies: 288
    Last Post: - 25th August 2008, 17:53
