I am confuse
Results 1 to 20 of 20
Thread: I am confuse
    Aug 2009
    Red face I am confuse
    Hi, I am trying to use the 16f88 ability for read analog voltages. I need to use analog inputs RA0-RA3. My initial settings are as follows:
    ANSEL = %00001111 'set RA0-RA3 as analog inputs
    ADCON1 = %10000000 'Right Justifies 10-bit value
    OSCCON = $60 'Sets the internal oscillator to 4 Mhz
    DEFINE ADC_BITS 10 ' Sets the number of bits in the result to 10
    ti var byte
    ti = 50 '50 MILLISECONDS DELAY'
    A var word ‘ A,B,C and D as variables
    B var word
    C var word
    D var word
    TRISA = %00001111
    TRISB = 0 ‘Turn PORT B as outputs
    I am using RA5 as my communication out to the LCD. (Internal clock). I am using also the 8 pins Portb for controlling two steps motors. Problem here is that if I ground the input pins (just for testing) I should get zero voltages and I don’t. I am using a 1K resistor to ground. For sure I am missing something here. Please advice.
    With out seeing your code try setting the ADC for 8 bits and see what happens.
    Wink
    Set comparators OFF ...
    ADCON0 = ?
    I think this chip has the comparators off on reset. I need to double check.
    Thinking more along the lines of not reading both the high and low bytes of the 10 bit setup might be the problem???
    Wink
    Hi, Dave
    you're right ... I never trust in defaults ... ( overhead, yes ... but sleeping nights ...)
    what about this one :
    TRISA = %00001111
    RA5/MCLR/VPP bit 5 ST Input, Master Clear (Reset) or programming voltage input.
    Alan,
    That would make the display act funny
    Aug 2009
    Well, first I did was to change the out pin to the LCD (Sorry I was using RA6 not RA5) to PortB.1 as for the test only. Second, I changed ADC to 8 bits and it went to zero but refuse to read any change voltage so I set it to back to 10. I wonder how can I set the AD comparators off using ADCON0. I read the 16F88 spec sheet page 114 and I don’t find a way to turn those comparators off. Please advice.
    I picked up the below method of reading the ADC here
    http://www.rentron.com/PICX2.htm
    I like it much better than ADCIN.
    The below code is an example for reading ADC channel 0. Look at the example on the above link to add other channels.
    It looks like a lot of stuff to do to read the ADC, pretty much what ADCIN does behind the scenes. This way you have control.
    The "READ_AD" part is only needed once no matter how many channels you are reading (reusable).
    Use your LCD or SERIAL to see what is happening. I have this running at 2400 baud. Works OK with the internal OSC for testing.
    [color=#000000]    '16F88 ADC TEST  FOR CHANNEL 0
        OSCCON = %01100000
        @ __config _CONFIG1, _INTRC_IO & _WDT_OFF & _LVP_OFF & _MCLR_OFF &_CP_OFF
        ANSEL = %00001111
        TRISA = %11111111
        CHAN0  VAR WORD   'VAR TO HOLD ADC0 READING
        START:
        HIGH PORTB.3    'HEART BEAT
        PAUSE 250
        LOW PORTB.3
        PAUSE 250
        'BELOW WILL SHOW WHAT THE ADRESH AND ADRESL REGISTER HOLDS
        SEROUT2 PORTB.2, 16780, ["ADRESH ",DEC ADRESH," ADRESL ",DEC ADRESL,$a,$d]
        PAUSE 50
        'BELOW SHOWS THE 10 BIT READING OF ADC0 IN VAR CHAN0
        SEROUT2 PORTB.2, 16780, ["CHAN0 ",DEC CHAN0,$a,$d]
        GOSUB ADC_0      'STARTS THE READING OF ADC CHANNEL 0
        GOTO START
        ADC_0:       'READ AN0
        ADCON1 = %10000000      'SET FOR 10 BIT
        ADCON0 = %00000001      'TURNS ADC ON
        GOSUB   READ_AD
        CHAN0.HighByte = ADRESH  'PLACES THE HIGH AND LOW BYTE
        CHAN0.LowByte  = ADRESL   'INTO VAR CHAN0
        READ_AD:   'DOES THE ADC CONVERSION
        PAUSE   50
        ADCON0.2 = 1
        PAUSE   50
    You can actually improve on that Dave...
    Instead of...
    ADCON0.2=1
    PAUSE 50
    ... which makes the assumption that your ADC reading will complete in 50mS... well - suppose it didn't? And suppose it only took only 50uS then you've wasted a shed load of time!
    So, rather than a hit or miss approach, nail it properly...
    ADCON0.2=1
    WHILE ADCON0.2=1:WEND
    To find out why I've done this, read the Datasheet description for pin ADCON0.2
    Post
    A2D8.bas example program, in the SAMPLES Folder ...
    While ... Wend did not exist in those prehistoric times this example was written ...
    Still no code available from tim ???
    COOL!!!
    This is what I have said. You learn by trying to help.
    Been using something like I posted all along and of course I have read that part about that bit but it never clicked...
    Maybe that is why it is called GO/DONE
    Prehistoric??? Maybe there is another message here.
    Well even in prehistoric times IF was available to you...
    	ADCON0.2=1
    ADCTIMEOUT:
    	IF ADCON0.2=1 THEN ADCTIMEOUT
    Wink
    Hi, Mel
    my prehistorics datings ( 14 Carbide ...) are V2.21 ...
    mainloop: ADCON0.2 = 1		' Start Conversion
    notdone: Pause 5
    	If ADCON0.2 = 1 Then notdone	' Wait for low on bit-2 of ADCON0, conversion finished
    	adval = ADRESH		' Move high byte of result to adval
    of course it's impossible you knew it, may be your grand'dad ...
    I suspect " Pause 5 " here for 10,000 microns handcarved silicium "1650" processor ( PIC's ancester )...
    Aug 2009
    Red face I am back...
    Well after reading all of your posts and did some research on the 16f88 datasheet I applied some changes to my own program that looks it has improved. With all channels 0 to 3 straight to ground I got channels 2 and 3 to 0 and channels 0 and 1 to some value of 14. I am adding the program listing for your evaluation. Thank you in advance.
    @ __config _CONFIG1, _INTRC_IO & _WDT_ON & _LVP_OFF & _CP_OFF
    INCLUDE "modedefs.bas"
    CMCON = 7 'Comparators off
    ti var byte
    ti = 50 '20 MILLISECONDS DELAY'
    A VAR word
    B VAR word
    C VAR word
    D VAR word
    TRISA = %00001111
    TRISB = 0 'TURN PORT B as outputs but RB1 WHEN USE ICD FOR COMMUNICATION
    '* * * * * MAIN PROGRAM START HERE * * * * * * * *
    PAUSE 1000
    Serout PORTB.1, 0, [254,1]
    Serout PORTB.1, 0, [254,2]
    PAUSE 20
    READSENSORS:
    ADCON0 = %00000001 'Turn ON CHAN 0
    GOSUB ADCON
    A.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    SEROUT PORTB.1 , 0, ["Ch 0= ",# A.LOWBYTE]
    pause 20
    ADCON0 = %00001001 'Turn ON CHAN 1
    GOSUB ADCON
    B.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    SEROUT PORTB.1 , 0, [" Ch 1= ",# B.LOWBYTE]
    PAUSE 20
    SEROUT PORTB.1,0,[$FE,$C0]
    ADCON0 = %00010001 'Turn ON CHAN 2
    GOSUB ADCON
    C.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    SEROUT PORTB.1 , 0, ["Ch 2= ",# C.LOWBYTE]
    PAUSE 20
    ADCON0 = %00011001 'Turn ON CHAN 3
    GOSUB ADCON
    D.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    SEROUT PORTB.1 , 0, [" Ch 3= ",# D.LOWBYTE]
    PAUSE 1000
    GOTO READSENSORS ' PROVISIONAL LOOP TO CHECK THE A/D CONVERTION.
    '* * * * * * * * * SELECTING THE MOTOR MOVEMENT * * * * * * * *
    IF A =0 and D =0 or C =0 and b =0 THEN GOTO READSENSORS 'IT IS DARK
    IF ABS (A-D)<10 OR ABS (B-C)<10 THEN GOTO READSENSORS 'IT IS ALIGNED
    If (B>D) OR (A>C) Then gosub Front
    IF (A>B) OR (C>D) THEN GOsub Left
    IF (C>A) OR (D>B) THEN GOsub Back
    IF (D>C) OR (B>A) THEN GOsub Right
    GOTO READSENSORS 'STAY FOR EVER LOOPING
    '* * * * * * * * * MOTOR'S MOVEMENTS SUBRUTINES * * * * * * * *
    Front:
    Serout PORTA.6, 0, ["FRONT ",# ABS (B-D)," ",# ABS (A-C)]
    SEROUT PORTA.6, 0, [$FE,$C0]
    PORTB = 1 'GOING FRONT
    PAUSE TI
    PORTB = 2
    PAUSE TI
    PORTB = 4
    PAUSE TI
    PORTB = 8
    PAUSE TI
    LEFT:
    Serout PORTA.6, 0, ["LEFT ",# ABS (a-b)," ",# ABS (C-D)]
    PORTB = 128 'GOING LEFT
    PAUSE TI
    PORTB = 64
    PAUSE TI
    PORTB = 32
    PAUSE TI
    PORTB = 16
    PAUSE TI
    Back:
    Serout PORTA.6, 0, ["BACK ",# ABS(C-A)," ",# ABS(D-B)]
    PORTB = 8 'GOING BACK
    PAUSE TI
    PORTB = 4
    PAUSE TI
    PORTB = 2
    PAUSE TI
    PORTB = 1
    PAUSE TI
    RIGHT:
    Serout PORTA.6, 0, ["RIGHT ",# ABS(D-C)," ",# ABS(B-A)]
    PORTB = 16 'GOING RIGHT
    PAUSE TI
    PORTB = 32
    PAUSE TI
    PORTB = 64
    PAUSE TI
    PORTB = 128
    PAUSE TI
    ADCON:
    ADCON1 = %10000000 'SET FOR 10 BITS
    ADCON0.2 = 1 'IT'S ONE TILL IT READS
    WHILE ADCON0.2 = 1 : WEND
    I am probably missing something but give this a shot.
    ti var byte
    A VAR word
    B VAR word
    C VAR word
    D VAR word
    TRISA = %00001111
    PAUSE 1000
    PAUSE 20
    READSENSORS:
    GOSUB ADCON
    pause 20
    GOSUB ADCON
    PAUSE 20
    GOSUB ADCON
    PAUSE 20
    GOSUB ADCON
    PAUSE 1000
    ADCON:
    This is what I am basing the sequence on. From the data sheet.
    1. Configure the A/D module:
    • Configure analog/digital I/O (ANSEL)
    • Configure voltage reference (ADCON1)
    • Select A/D input channel (ADCON0)
    • Select A/D conversion clock (ADCON0)
    • Turn on A/D module (ADCON0)
    I am pretty sure this sequence needs to be followed. I am not at the shop so I can not test your code now.
    Wink
    Hi, Dave and Tim
    I had a look to the TEST section of this program ... It gave that, with a " classic " PBP use. :
    'Config
    @	__CONFIG    _CONFIG1, _CP_OFF & _CCP1_RB3 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_ON & _PWRTE_ON & _WDT_ON & _INTRC_IO
    @ 	__CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
    '@ __config _CONFIG1, _INTRC_IO & _WDT_ON & _LVP_OFF & _CP_OFF
    'ADCON1 = %10000000 'Right Justifies 10-bit value
    'OSCCON = $60 'Sets the internal oscillator to 4 Mhz
    OSCCON 	= %01101110 'Internal RC w/ I/Os
    INTCON	= 0
    PIE1	= 0
    PIE2	= 0
    CVRCON 	= 0
    ti var byte
    A VAR word
    B VAR word
    C VAR word
    D VAR word
    _A CON 0
    _B CON 1
    _C CON 2
    _D CON 3
    TRISA = %00001111
    PAUSE 1000
    PAUSE 20
    READSENSORS:
    'ADCON0 = %00000001 'Turn ON CHAN 0
    'GOSUB ADCON
    ADCIN _A, A
    'A.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    pause 20
    'ADCON0 = %00001001 'Turn ON CHAN 1
    'GOSUB ADCON
    ADCIN _B, B
    'B.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    PAUSE 20
    'ADCON0 = %00010001 'Turn ON CHAN 2
    'GOSUB ADCON
    ADCIN _C, C
    'C.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    PAUSE 20
    'ADCON0 = %00011001 'Turn ON CHAN 3
    'GOSUB ADCON
    ADCIN _D, D
    'D.LOWBYTE = ADRESL 'PLACES THE LOW BYTE INTO VAR
    PAUSE 1000
    I just commented out original lines for comparison ...
    Hope it Helps
    Aug 2009
    Default Problem solved.
    I did the two editing of my program as Acetronics and as Mackrackit subjected. I ran both versions and ran with the same faulty results. I can’t understood how three persons could be wrong so I started again a check of my hardware. I found the problem on the breadboard. At the two power lines that runs on the outside of the board (-,+) the + line had 50 ohms! from one end to the other. I found a fault connection and restored it with a new line, problem goes. Now every input goes to zero. I want to thanks all of you including Melanie. Every time I come across an obstacle there is a reason to learn. Thanks.
    COOL!!!
    At least now you have a couple different ways to read the ADC.
    Have FUN!!!
    Aug 2009
    Default I had fun.
    Thank you. Yes I had a lot of fun with every project. I had to unassembled the breadboard and run a soldered copper line under all around it to ensure a good contact. That’s part of the fun also. Thanks.
  1. Replies: 288
    Last Post: - 25th August 2008, 16:53
