First time with external oscillator - 16F877a Not working
Results 1 to 9 of 9
    osc1=input
    osc2=output
    Using MPLAB, GOOD!
    First:
    Turn off the setting of the fuses in your programmer software and do it in code or the *.inc file.
    Second:
    To make this all digital use
    ADCON1=7
    CMCON=7
    Third:
    Try this code before you write something "looooong", just to make sure everything is working.
    '16F877A       HEART_BEAT
        @ __config _XT_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF &_BODEN_OFF
        ADCON1=7
        CMCON=7
    START:
        HIGH PORTD.2
        PAUSE 100
        LOW PORTD.2
        PAUSE 100
        GOTO START
    Exclamation
    Using MPLAB, GOOD!
    First:
    Second:
    ADCON1=7
    CMCON=7
    Third:
    '16F877A       HEART_BEAT
        ADCON1=7
        CMCON=7
    START:
        HIGH PORTD.2
        PAUSE 100
        LOW PORTD.2
        PAUSE 100
        GOTO START
    Hi, thanks for replying. My Loooong code is working fine (Code is good) on 16F690. I want to transffer the code to 16F877 but since it uses external oscillator and I have never used one before, I only have intentions to blink an LED first.
    I have tried your advise above but its not working still. Timing of blinking is not right (when it is blinking), it blinks sometimes when I touch the capacitor leg, touch the bench where the circuit is left on, sometimes its just sitting bright on. I feel the problem is with hardware configuration.
    I am building the circuit on a breadboard with 4MHz ceramic oscillator and two 22pF ceramic capacitors. But just don't know what is wrong and it is taking me towards insanity....
    ___________________
    WHY things get boring when they work just fine?
    Tell about the MCLR pin connection.
    Is it pulled high?
    Talking
    10 Bucks on Mackrackit ...
    Wink
    Did I mentioned that some people here really know there stuff?
    Thank you very much, this problem was due to MCLR!
    But
    I'LL BE BACK (with more problems ofcourse)
    ___________________
    Quote Originally Posted by bogdan View Post
    osc1=input
    osc2=output
    How do you figure that out with the ceramic oscillator? I only see two pins comming out and no specific I\O marking.
    ___________________
  1. I don't understand this code!
    Last Post: - 13th February 2008, 03:55
  2. Working with indivividual bytes of an array
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2007, 20:16
  3. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 20:55
  4. help with 16f628a
    By thalia in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2006, 09:16
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 15:24
