Synchronous pulses
Results 1 to 17 of 17
    Brussels, Belgium
    More or less makes sense.
    As I'm only juggling three outputs, I think I'll just sort the outputs into increasing time, calculate the incremental time between trailing edges, put them all on together and then pull them back down sequentially with PAUSEUS delays.
    Thanks for taking the time to answer
    Andrew
    Aug 2005
    Michigan, USA
    You're welcome.
    Good luck on your project.
    Regards, Mike
    Bombay, India
    This last post made me to put on my thinking cap I do this stuff within an ISR usually, but your case doesn't need it.
    How about something like this. BEWARE : untested code
    Out1    var   PORTB.0
    Out2    var   PORTB.1
    Out3    var   PORTB.2
    AllOn    con  %00000111      ' all three outputs on
    Delay1 var   word                 ' turn off delay for output1
    Delay2 var   word                 ' and 2
    Delay3 var   word                 ' surely this has to be for 3
    RunDelay var word               ' this is the running timer
    '  set all outputs on together
    TRISB = 0
    Delay1 = 1000                     ' in units of PAUSE time
    Delay2 = 2000
    Delay3 = 3000
    Loop:
        PORTB = AllOn
        for RunDelay = 0 to 65535  '  or whatever is the maximum you want
                                                   ' this would be your cycle  / repeat time
          if RunDelay > Delay1 then
             Out1 = 0
          if RunDelay > Delay2 then
             Out2 = 0
          if RunDelay > Delay3 then
             Out3 = 0
          pauseus 10                        ' this is the resolution of your delays
        next
    goto Loop
    Aug 2005
    Michigan, USA
    Hi Jerson,
    I agree that ISR code isn't necessary or even desirable in this case because of the high resolution required and the ISR context save/restore 'overhead'.
    Andrew mentioned in his first post that the pulse width range could be several microseconds up to about one millisecond.
    I believe the pulse width resolution for your example would be the loop code 'overhead' plus the 16-bit compare code 'overhead' plus the delay. The 16-bit compare code 'overhead' may well be the biggest limiting factor affecting resolution and the delay may not be necessary. Have you checked to see how many cycles are used for 1 loop cycle in your example Sir?
    Regards, Mike
    Aug 2005
    Michigan, USA
    Hey Andrew,
    Once I figure out how to force an address for the toggle array in Swordfish BASIC I suspect my method might look something like this BASIC example, which I hope makes more sense than my previous pseudo C example.
    Kind regards, Mike
    Dim Tgl(1024) As Byte                   ' ??? force to $400..$7FF ???
    Dim Pulse(3) As Word
    Dim LastElement As FSR0H.booleans(3)
        Pulse(0) = 3                        ' RB0 pulse, 0..1023 usecs
        Pulse(1) = 11                       ' RB1 pulse, 0..1023 usecs
        Pulse(2) = 12                       ' RB2 pulse, 0..1023 usecs
    '  clear the 1024 element toggle array
        FSR0 = AddressOf(Tgl)               ' indirect for Tgl(0)
        Repeat                              ' clear toggle array
            POSTINC0 = 0                    ' clear 0x400..0x7FF
        Until LastElement                   '
    '  insert 3 output toggle bits into our 1024 interval toggle array
        Tgl(Pulse(0)) = Tgl(Pulse(0)) Or 1  ' insert RB0 toggle bit
        Tgl(Pulse(1)) = Tgl(Pulse(1)) Or 2  ' insert RB1 toggle bit
        Tgl(Pulse(2)) = Tgl(Pulse(2)) Or 4  ' insert RB2 toggle bit
        Tgl(0) = Tgl(0) Xor $FF             ' prep Tgl(0) element
    '  implement a button press or some other trigger before falling into
    '  the output routine (1024 1-usec intervals with 20-MHz clock)
        FSR0 = AddressOf(Tgl)               ' Tgl(0..1023), 0x400..0x7FF
        Repeat                              ' toggle outputs from toggle array
            LATB = LATB Xor POSTINC0        ' at 1-usec (5 cycle) intervals
        Until LastElement                   ' until end-of-array (0x800)
  1. I Need Help.. I want to generate controlled pulses
    By alabbadi in forum PBP Wish List
    Last Post: - 18th November 2007, 10:42
  2. Count pulses between VARIABLE TIME
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 15th October 2007, 12:44
  3. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 01:50
  4. Timed pulses on 2 pins
    By Danie Joubert in forum mel PIC BASIC Pro
    Last Post: - 15th March 2004, 07:38
  5. Counting pulses
    By srspinho in forum mel PIC BASIC Pro
    Last Post: - 19th November 2003, 00:54
