from the PBP manual on the EEPROM command:
"The data is stored in the EEPROM space only once at the time the microcontroller is programmed, not each time the program is run. WRITE can be used to set the values of the on-chip EEPROM at runtime. READ is used to retrieve these stored DATA values at runtime."
If you intend the command where u use EEPROM to run every time you will have to use a series of WRITE commands instead.
