Help with button and 16F877a
Results 1 to 5 of 5
    Quote Originally Posted by gtrplaya101 View Post
    Thanks for the link.
    Is there not just a short command that I can place into the code that will change all of PortA pins to digital input?
    That's what AllDigital does ...
    INCLUDE "ALLDIGITAL.pbp"
    Would this work?
    CMCON = 7
    ADCON1 = 7
    Yes, that will work on a 16F877A.
    And is exactly what AllDigital would do.
    But when you go to use a different chip, those registers will probably not work anymore and you'll have to search the datasheets to see which ones are needed for that chip.
    AllDigital will still work no matter which chip you are using.
    thanks that did the trick!
  1. what's wrong 16F877A simple code?
    Last Post: - 30th October 2009, 02:11
  2. 16F877 vs. 16F877A
    By DavyJones in forum General
    Last Post: - 11th April 2009, 19:22
  3. Help Pbasic to PBP
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2009, 19:35
  4. button pullup/down resistor?
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 06:13
  5. Reaction timer using 16f877a and pbp
    By sphinxifm in forum mel PIC BASIC Pro
    Last Post: - 14th July 2007, 15:28
