Today I started to build a project with a variant of PIC I never used before, 16F876A, but since its the little brother of my old fauvorite pic 16F877A I didnt think it would be any problems..
HOWEVER..
I got LCD-problems, and they are so strange. ..To boil it down I wrote a short test program..
..The result is:Code:@ DEVICE PIC16F876A,HS_OSC,LVP_OFF,WDT_OFF,PROTECT_OFF DEFINE OSC 20 ' Lets work at 20 MHz ' DEFINE LCD_DREG PORTA ' Set LCD Data port ' DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus ' DEFINE LCD_RSREG PORTA ' Set LCD Register Select port ' DEFINE LCD_RSBIT 4 ' Set LCD Register Select bit ' DEFINE LCD_EREG PORTB ' Set LCD Enable port ' DEFINE LCD_EBIT 3 ' Set LCD Enable bit ' DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) ' DEFINE LCD_LINES 2 ' Set number of lines on LCD ' DEFINE LCD_COMMANDUS 1500 ' Set command delay time in us ' DEFINE LCD_DATAUS 44 ' Set data delay time in us pause 2000 ' Gracetime for the LCD Main: toggle PORTB.5 LCDOUT $FE, 1, "Hello" LCDOUT $FE, $C0, "World" pause 2000 LCDOUT $FE, 1, "1234567890123456" pause 500 LCDOUT $FE, 1, "ABCDEFGHIJKLMNOP" pause 500 LCDOUT $FE, 1, "abcdefghijklmnop" pause 500 goto main: End
First the display says
Hello
World
..Waits 2 seconds and then
34567890123456
waits .5 sec
CDEFGHIJKLMNOP
waits .5 sec
cdefghijklmnop
waits .5 sec
llo
World
..and then continue..
Why is it eating the two leading chars ? ..I tried the display on another breadboard with an
16F877A, works perfectly fine..
I tried to add all defines, and tweak some values (currently commented out in the code), no difference.
Any ideas ?
