Problem receiving string
Results 1 to 3 of 3
Threaded View
  1. #3
    May 2008
    Italy
    Or...
    You can use the time out to check your array string.
    serin2 rx,baud,5000,main,[WAIT("REC UNREAD"),SKIP 3,STR num\13,SKIP 27,STR sms\14]
    From the above code, if you don't receive the whole string (14 characters) then at timeout, program will jump to label main, here you can check your array sms
    A0=0
    for B0=0 to 13
    if sms[B0]>0 then A0=A0+1
    next B0
    If A0 >0 then goto decode
    If variable A0 is found >0 then your array has been loaded and program jump to label Decode where you will decode sms array from sms[0] to sms[A0-1].
    Is there any way I can make this code work if it receives from 1 to upto 14 characters.
    Once in routine Decode,A0 can be anything from 1 to 14 just what you where searching for.
    Naturally, before to go to Serin2 you must clear (set to zero) the array sms.
    Al.
  1. Receiving Different String lengths
    By Jannie in forum Serial
    Last Post: - 26th January 2009, 06:00
  2. Floating Point Display Problem (serial string out)
    By Cash Olsen in forum mel PIC BASIC Pro
    Last Post: - 20th December 2007, 03:03
  3. Math problem with string result
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 11:06
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  5. USART Problem Receiving Bytes
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 15th September 2005, 18:50
