Problem receiving string
Results 1 to 3 of 3
    Question Problem receiving string
    Hello
    I am trying to use the following command:
    serin2 rx,baud,5000,main,[WAIT("REC UNREAD"),SKIP 3,STR num\13,SKIP 27,STR sms\14]
    I am trying to build an sms controller using my GSM modem with 16F690
    My problem is that this code only moves forward if the string is 14 bytes long.
    Is there any way I can make this code work if it receives from 1 to upto 14 characters.
    Any input will be much appreciated. Thanks
    ___________________
    WHY things get boring when they work just fine?
    Bombay, India
    This should work for a CR terminated string. It will collect uptil CR or 14 characters.
    serin2 rx,baud,5000,main,[WAIT("REC UNREAD"),SKIP 3,STR num\13,SKIP 27,STR sms\14\13]
    From the manual :
    STR ArrayVar\n{\c} - Receive string of n characters optionally ended in character c
    May 2008
    Italy
    Or...
    You can use the time out to check your array string.
    From the above code, if you don't receive the whole string (14 characters) then at timeout, program will jump to label main, here you can check your array sms
    A0=0
    for B0=0 to 13
    if sms[B0]>0 then A0=A0+1
    next B0
    If A0 >0 then goto decode
    If variable A0 is found >0 then your array has been loaded and program jump to label Decode where you will decode sms array from sms[0] to sms[A0-1].
    Once in routine Decode,A0 can be anything from 1 to 14 just what you where searching for.
    Naturally, before to go to Serin2 you must clear (set to zero) the array sms.
    Al.
  1. Receiving Different String lengths
    By Jannie in forum Serial
    Last Post: - 26th January 2009, 05:00
  2. Floating Point Display Problem (serial string out)
    By Cash Olsen in forum mel PIC BASIC Pro
    Last Post: - 20th December 2007, 02:03
  3. Math problem with string result
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 10:06
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 04:39
  5. USART Problem Receiving Bytes
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 15th September 2005, 17:50
