can't solve this voltage measurement problem
Results 1 to 14 of 14
    New Jersey
    Default can't solve this voltage measurement problem
    I have a 16F688 that is measuring voltage from a battery (and battery charger from a forklift battery) that closes a relay when it reaches a voltage. Everything works OK (there are some additional functions) but there is way too much noise on the input to the PIC pin from the battery charger.
    The input comes into the PIC through a voltage divider, .1uf cap and a half-wave rectifier. I've tried many things but I cannot solve this problem. The AC ripple on the DC is about 5VAC and I have little experience with solving AC ripple problems. The chargers are old and giving me huge headaches!!!
    What else can I do to solve this problem?
    Bombay, India
    You haven't mentioned the frequency of the ripple. Is it AC mains? If it is, 0.1uF is too small a capacitor to smooth that ripple. I would say, a safe starting value should be in the 10s of uF. You also mention having a half wave rectifier prior to the measurement, so, you should be able to smooth it real good if you increase that capacitor.
    Can you post a schematic? It might help understand the problem better.
    May 2008
    Italy
    Christopher4187 the attached ripple chart could help you in choosing the right capacitor for your specific problem. (Mind the chart is for 60 Hz, for a different frequency you have to adjust it.).
    Al.
    New Jersey
    Jerson,
    I've attached a quick drawing of the circuit. The problem is, I don't have the piece of equipment with me but if I remember correctly, the frequency is 500Hz but it is very erratic. Not only that, not all pieces of equipment have this problem because some are new chargers and some are old. It's not AC mains, it's the output of the battery charger.
    Bombay, India
    Try something like this
    New Jersey
    Thanks Jerson. I realized I drew it wrong because I had the diode on the input to the voltage divider. If not, my measurement would be WAYYYY off!!! I'll try the increased cap size. I didn't put it at the input to the voltage divider because the size would have to be much bigger. How important is it to have the cap before the voltage divider instead of after?
    Sep 2005
    Campbell, CA
    It also wouldn't hurt to take an average. Since 60 Hz has a period of 16.66 milliseconds, and an A/D conversion takes about 30uSecs, you could average 16 samples (a full cycle) something like this:
       ADCAvg = 0            ; Clear the variable
    For X = 1 to 16
       ADCIN,x, ADCresult
       ADCAvg = ADCAvg + ADCresult
       Pauseus 1000
       Next X
    ADCAvg = ADCAvg >> 4    ; divide by 16
    This should do a pretty good job of smoothing the result.
    Charles Linquist
    New Jersey
    I've tried all kinds of software routines but nothing seemed to help. I think the AC ripple is not a normal sine wave, maybe that's why.
    Put a 1uF Electrolytic... or even a 10uF... across the 0.1 Capacitor.
    It's a Battery Charging circuit - you don't need instantaneous results. If your filters time period is a few hundred mS then goodbye to any 500Hz noise! Make sure you haven't got any noise on your 5v line - that could be throwing +VRef as well.
    Oct 2009
    I accept: it is hurt to take an average. Since 60 Hz has a period of 16.66 milliseconds, and an A/D conversion takes about 30uSecs.
    New Jersey
    Would this work or can I get rid of the .1uF cap? What type of cap (material) should I use?
    Also, should I put a 1uF cap in the input to the PIC (it's also my vref voltage)? As Melanie said, this could be causing me problems too.
    Apr 2006
    New Hampshire USA
    Exclamation Voltage Divider
    Quote Originally Posted by Christopher4187 View Post
    Hi Christopher,
    That first circuit you attached would send 50 Volts to the PIC!
    This is more like a voltage divider.
    <IMG SRC=" http://www.picbasic.co.uk/forum/attachment.php?attachmentid=3761&stc=1&d=125658271 3">
    -Adam-
    Last edited by Pic_User; - 26th October 2009 at 18:52. Reason: keep up with other edits
    New Jersey
    I've decided to put the 10uF cap after the voltage divider so the voltage should not be higher than 5V. Can someone just check and see if this capacitor would be sufficient for my issue please?
    It's digikey number 445-2863-ND
    Thanks in advance!
    timmers's Avatar
    timmers Guest
    You're all close, but not quite on the mark. Putting the diode in will rectify the noise, and all you will be measuring is peak noise.
    PIC_USER was close, but if you removed D1, C2, R3 and R4 then you will be creating a potential divider with a low pass filter, and be measuring the average voltage. I would however add a zener diode where R3 is to prevent any overvoltage problems, say a 5v6.
    Values of R1 / R2 would depend on how high you wish to make the impedance, but to get a decent RC timeconstant I would be looking around 68k for the top and 5k6 for the bottom, works out as around 3.8volts into the A2D pin from 50v.
    This would filter off most of the noise above 15hz with a 1uF capacitor.
    Other option is to A2D the full bandwidth and do some averaging in software and calculate the RMS value. But thats not easy and is heavy on register resources.
    Hope this helps.
    Timmers.
  1. Replies: 19
    Last Post: - 27th May 2010, 03:56
  2. Expanded Scale Voltmeter
    By Pic_User in forum Schematics
    Last Post: - 8th February 2008, 20:32
  3. Replies: 6
    Last Post: - 10th January 2008, 10:38
  4. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
  5. Need Help in Measurement of Voltage
    By apache in forum General
    Last Post: - 5th June 2005, 15:39
