How to make your own PIC network
Results 1 to 20 of 20
    Oct 2006
    Default Til81
    hi all
    i need a help. i m using til81(phototransistor) in the receiver side,and an led r IRled or LED55 n the transmitter side.if the light intensity frm the transmitter s varied the output of the til81 should vary.but for me,i m using ordinary led,but the output s not varying if i provide any obstacle.plz any one help me to get the datasheet for til81plz help me
    Sakthi
    Quote Originally Posted by sakthi View Post
    hi all
    Sakthi
    And you want to program it in C right?
    Feb 2003
    Not sure why but I have stange feeling of Deja Vu
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Quote Originally Posted by keithdoxey View Post
    In these cases, I get 'Vu Ja De'... (Voo Zya Day, not Day Zya Voo)
    ya know, that feeling that you've never been there in a situation nothing like that before
    Not sure of this 'Vu Ja De' expression... more than likely it's 'Déja Vue'. It's a french expression wich mean 'Already seen' not much.
    In PBP...
    Vu Ja De = ~ ( Deja Vue )
    hi all
    Sakthi
    here : http://www.datasheetarchive.com/data...rticle=3723931
    PS ... think to remove dust from that chip, I've some here dating from the 70's.
    May be your range problems come from that ???
    Feb 2007
    Default Dmx adress
    dear mister_e;
    i see that you dont use "rx" or "tx" pin for receive?
    how can i make your master for dmx 512 decode and your slave to receive for 512adress i know i have tome add 9 dipsw on it and i will use it only for 3 leds no more 3 chanel is ok for me can you help?
    slave for 512dmx adres receive and 3 output in 250000baudrate ?
    What you need to do is not as this simple for a first school project.
    DO you at least readed some info about DMX and their timing charts?
    anyway, 512 channel will need 9 dip switch indeed. so at least one 8bit pot + another elsewhere.
    DMX VAR WORD
    DMX.LowByte=PORTB
    DMX.8=PORTA.0
    The above give you the switch setting, now you just need to be in synch with the DMX break... then count untill you reach the right channel. How to? I know how AND i know my name will NEVER appear on your school report... so try few things, understand how serial communication works at least... then once you have understand it and read ALL links i already sent on various post... we can talk about a little bit more help.
    Google have tons of DMX example... even using the most stupid controller in whole world.. 16F84. Ok it was good 10 years ago....
    http://www.dmx512-online.com
    http://www.erwinrol.com/index.php?stagecraft/dmx.php
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 09:54
  2. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 00:52
  3. PIC network over AC 220V
    By boban in forum Schematics
    Last Post: - 6th June 2007, 10:31
  4. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 20:42
