Assembly Language inside PBP
Results 1 to 5 of 5
    Bombay, India
    You can try this.
    movlw 1
    addwf _Rain ; increment the LSB
    btfsc STATUS,C ; if overflow, increase MSB
    incf _Rain+1
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default BYTE/WORD in Assembler
    Thanks Jerson - I will give it a go.
    I presume that PBP allocates two BYTES of memory to the WORD sized variable 'RAIN' and the assembler routine only deals with one of them?
    I guess I could create two BYTES to hold the RAIN data and increment the 'higher' BYTE if there is a carry from the 'lower' - Seems a bit cumbersome and I was looking for a neater/easier way.
    Regards Bill Legge
    Wink
    Quote Originally Posted by Bill Legge View Post
    Hi, Bill
    As the 18F1220 is a 8 bits processor ... the neater/easier way is to use a 16 bits device !!!
    not obvious easier, eh ???
    NOW, The "DT Instant interrupts" might do the trick " neater " ( sic ) ... it's not raining as the "Niagara falls" , after all ...
    OR use one of the chip 16 Bits counters ... you have 3 aboard, after alll ...
    Simple addition or incrementing variables doesn't use the system registers.
    So it's ok to break out of ASM and do it with PBP.
    Rain   VAR WORD
    MyInt
        ;save context
        ;asm part here
          Rain = Rain + 1
        ;more asm here
        ;restore context
        retfie
  1. Replies: 2
    Last Post: - 8th February 2009, 06:10
  2. Assembly Language Conflict
    By NO2K in forum General
    Last Post: - 24th July 2007, 01:42
  3. Passing arrays PBP <-> Assembly
    Last Post: - 16th April 2006, 02:01
  4. Assembly Language + PBP
    Last Post: - 10th January 2006, 14:54
  5. Replies: 2
    Last Post: - 8th August 2004, 17:00
