PBP Using too many instructions
Results 1 to 15 of 15
    Quote Originally Posted by The Master View Post
    ... In this case the multiple if statements are required.
    I have my doubts about that.
    Multiple IF statements usually just means Spaghetti.
    How would i go about doing the ASM macro thing?
    Well, here's one way ...
    IfEqual  macro Bin, Cin, Lin          ; Bin is a BYTE variable
        RST?RP                            ; Cin is a constant to campare against
        movlw   Cin                       ; Lin is a label to jump to ...
        subwf   _vPWMPos,w                ;   if the condition is false
        btfsc   STATUS, Z
        goto    Lin
    ;-----[Here's how you use it]----------------------------------------------
    @  IfEqual  _vPWMPos, 1, _L1
      ; code here executes if _vPWMPos = 1
    L1:
    @  IfEqual  _vPWMPos, 2, _L2
      ; code here executes if _vPWMPos = 2
    L2:
    In most cases, it will take 4-5 instructions.
    But care must be taken to insure it doesn't cross a Page Boundary.
    I still think you'll be better off using BRANCH.<hr>
    I think this would probably work "pin = (pinValue=PWMPos)" but i wonder if that would get compiled to the same kind of code as an if statement.
    That way only works if you can use the inverse of the result ...
    myPIN = !(pinValue = vPWMPos)
    Of course, the inverse of that is ...
    myPIN = !(pinValue != vPWMPos)
    Last edited by Darrel Taylor; - 11th October 2009 at 05:49. Reason: Modified macro
    Jun 2007
    Mansfield, UK
    Heres what my code looks like
    IF vPWMPos=vPWM[0] THEN pA1=1
    IF vPWMPos=vPWM[1] THEN pA2=1
    IF vPWMPos=vPWM[2] THEN pA3=1
    IF vPWMPos=vPWM[3] THEN pA4=1
    IF vPWMPos=vPWM[4] THEN pA5=1
    IF vPWMPos=vPWM[5] THEN pA6=1
    Multiple ifs are needed because its possible for all of the vPWM values to be the same.
    That ASM looks complicated but ill try and figure it out.
    Im not at the PC i program on at the moment. Do you know if setting the value directly would work and if it does how many instructions it would take?
    That code is completely different from what you originally asked about.
    Now you've got Array's involved.
    When you get back to the PC, post what you have.
    I'll take another look at the "Real" question.
    But I still smell spaghetti.
    Jun 2007
    Mansfield, UK
    The code i posted originally is what ive been using to test how many instruction cycles things take. I have 4 sockets (A to D) on this board each with 6 outputs (1 to 6).
    'Define output pins
    pA1 VAR PORTB.1
    pA2 VAR PORTB.2
    pA3 VAR PORTB.0
    'etc...
    'Then further down inside the TMR0 interrupt
    'Is the vPWMPos equal to 0?
    IF vPWMPos=0 THEN
    	'Turn off any outputs that are less than 255
    	IF vPWM[0]<255 THEN pA1=0
    	IF vPWM[1]<255 THEN pA2=0
    	IF vPWM[2]<255 THEN pA3=0
    	'etc...
    	'If vPWMPos is less than any of the chanels then turn those chanels on
    	'etc...
    'Decrement the PWM counter
    vPWMPos=vPWMPos-1
    There doesnt have to be an array involved. I just used that to make other parts of the code a little easier. I could create a bunch of variables named vPWM0, vPWM1 etc instead. The important part is reducing the number of instructions an if statement uses or not using an if statement at all.
    Aug 2005
    Michigan, USA
    Soft' PWM for that many outputs is difficult but you might be able to reduce 'overhead' using one of the following assembler methods;
    Good luck on your project Sir. Regards, Mike
    ;  6 bit (single port), 256 step, 20 cycles (isochronous) for 16F
            movf    led+5,W         ; led[5] duty cycle, 0..255       |B0
            subwf   dcy,W           ; C = led[5] >= dcy               |B0
            rlf     shadow,F        ;                                 |B0
            movf    led+4,W         ; led[4] duty cycle, 0..255       |B0
            subwf   dcy,W           ; C = led[4] >= dcy               |B0
            rlf     shadow,F        ;                                 |B0
            movf    led+3,W         ; led[3] duty cycle, 0..255       |B0
            subwf   dcy,W           ; C = led[3] >= dcy               |B0
            rlf     shadow,F        ;                                 |B0
            movf    led+2,W         ; led[2] duty cycle, 0..255       |B0
            subwf   dcy,W           ; C = led[2] >= dcy               |B0
            rrf     shadow,F        ;                                 |B0
            movf    led+1,W         ; led[1] duty cycle, 0..255       |B0
            subwf   dcy,W           ; C = led[1] >= dcy               |B0
            rlf     shadow,F        ;                                 |B0
            movf    led+0,W         ; led[0] duty cycle, 0..255       |B0
            subwf   dcy,W           ; C = led[0] >= dcy               |B0
            rlf     shadow,F        ;                                 |B0
            xorlw   0xFF            ; for active hi outputs           |B0
            movwf   PORTB           ; update LEDs                     |B0
    ;  bump duty cycle counter
            movlw   b'00111111'     ; just in case                    |B0
            incf    dcy,F           ; bump duty cycle counter         |B0
            skpnz                   ; end-of-period? no, skip, else   |B0
            movwf   shadow          ; reset shadow                    |B0
    ;  6 bit (single port), 256 step, 15 cycles (isochronous) for 18F
            movf    dcy,W           ; duty cycle counter, 0..255
            cpfsgt  Led+0           ; if(Led[0] >= dcy)
            bcf     Shadow,0        ;   Shadow.0 = 0
            cpfsgt  Led+1           ; if(Led[1] >= dcy)
            bcf     Shadow,1        ;   Shadow.1 = 0
            cpfsgt  Led+2           ;
            bcf     Shadow,2        ;
            cpfsgt  Led+3           ;
            bcf     Shadow,3        ;
            cpfsgt  Led+4           ;
            bcf     Shadow,4        ;
            cpfsgt  Led+5           ;
            bcf     Shadow,5        ;
            movff   Shadow,LATB     ;
            infsnz  dcy,F           ; if end-of-period
            movwf   Shadow          ; reset shadow
    Bombay, India
    Jun 2007
    Mansfield, UK
    Ive been trying to get my head round this ASM code. Mike's ASM seems to do almost exactly what i want but i just want to clarify things as im completely new to ASM.
    Is W some kind of temp byte? It appears that ASM compare commands only accept 1 input and that is always compared with W.
    Ive read the part in the datasheet about CPFSGT. It says "Compare f with W, skip if f > W". I assume this means skip the following line of code
    BCF looks pretty obvious. What is "Shadow" though? Is that a predefined variable of some kind or does it need declaring anywhere?
    Aug 2003
    Just looking at that, why not make the "pA" variables an array as well and just:
    FOR  BLA = 1 to 6
    IF vPWMPos=vPWM[BLA-1] THEN pA[BLA]=1
    NEXT BLA
    Otherwise I don't see how your claim that the array made things easier could be possible.
    Jun 2007
    Mansfield, UK
    pA1 etc are references to output pins. In PBP you cant have an array that references anything else. Loops also take up extra instructions and in this case using less instructions is more important than writing neat code.
    Aug 2003
    Pity about a loop using more words. I wouldn't have thought so with so many IF statements.
    I wonder if this would work to access ports as an array
    vPWMPos var byte
    vPWM var byte[6]
    pA var portb.0
    BLA var byte
    FOR BLA = 0 TO 6
    IF vPWMPos=vPWM[BLA] THEN pA[BLA]=1
    NEXT BLA
    In C, you can access arrays out of bounds like that, and we know portb pins are in consecutive memory locations.
    . Don't know with PBP though.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. PBP, ASM and LST files
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th January 2010, 14:43
  3. List of instructions used in PBP ?
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2007, 12:22
  4. Compiler differences between PBP 2.33 & 2.46
    Last Post: - 2nd May 2006, 20:01
  5. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
