Help with button and 16F877a
Results 1 to 5 of 5
    Default Help with button and 16F877a
    Hi all! As you can see I am a new member here and even greener in the world of MCUs. So far I have been able to successfully accomplish small feets in programming such as interfacing a serial LCD, blinking an LED, etc. However I am having trouble getting a button to work. What I am trying to do is get a button input on PortA.2 to turn on an LED connected to PortA.1. I can turn the LED on and off I just cant get the button input to work. Not sure if I have the pin configured incorrectly but any help would be greatly appreciated!!!
    Since you're using PORTA (Analog pins) as digital ...
    I might suggest ...
    ALLDIGITAL.pbp
    http://www.picbasic.co.uk/forum/showthread.php?t=11100
    Thanks for the link.
    Is there not just a short command that I can place into the code that will change all of PortA pins to digital input? I have been able to get the button to work on PortB so I am sure my code is right, is just doesnt work on PortA.
    Sorry for the newb questions!
    Would this work?
    CMCON = 7
    ADCON1 = 7
    Quote Originally Posted by gtrplaya101 View Post
    That's what AllDigital does ...
    INCLUDE "ALLDIGITAL.pbp"
    Would this work?
    CMCON = 7
    ADCON1 = 7
    Yes, that will work on a 16F877A.
    And is exactly what AllDigital would do.
    But when you go to use a different chip, those registers will probably not work anymore and you'll have to search the datasheets to see which ones are needed for that chip.
    AllDigital will still work no matter which chip you are using.
    thanks that did the trick!
  1. what's wrong 16F877A simple code?
    Last Post: - 30th October 2009, 02:11
  2. 16F877 vs. 16F877A
    By DavyJones in forum General
    Last Post: - 11th April 2009, 19:22
  3. Help Pbasic to PBP
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2009, 19:35
  4. button pullup/down resistor?
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 06:13
  5. Reaction timer using 16f877a and pbp
    By sphinxifm in forum mel PIC BASIC Pro
    Last Post: - 14th July 2007, 15:28
