How powering PIC in auto ?
Results 1 to 20 of 20
    I use a Digi-key 497-6469-1-ND Transient Voltage Suppressor
    on every outside lead connected to the circuit.
    I believe they are much faster than old zener clamps.
    Also try to add a 100 ohm resistor or better ahead of each TVS so it doesn't
    have to pull the spike down in the entire system.
    For the power supply their could also be a diode and a 100 ohm resistor in
    series followed by a large capacitor and TVS in parallel to ground ahead of
    the volt regulator.
    The 100 ohm resistor can get hot depending on the current draw.
    You may have to adjust to less than 100 ohm to maintain voltage at peak
    current draw.
    Norm
    Dec 2008
    Ploiesti, ROMANIA
    @ Normnet : Can You figure that on my schematic ? Thank You !
    Dec 2007
    Finland
    Post
    If you are using surface mounted components (0603 or smaller), then it would be more wise to put ESD protection before any serial resistor. Resistor will burn or change value if you force ESD current to go thru it.
    Old thru mounted comps can tolarate more ESD, but even with those I would recommend to do the same.
    For ESD protection you can use: TVS, varistor or zeners. All those will give appropriate protection, if you have done your PWB layout correct way. Try to minimize all paracitic impedances (inductances & resistance) from ESD current paths.
    BR,
    -Gusse-
    Dec 2008
    Ploiesti, ROMANIA
    I understand...Thanks ! Just because it's cheap, can I use "Transient Voltage Suppressors (TVS)" VC 1206 05 D 150 (05 = 5.6 VDC Working voltage; D=0.4 J Energy ; 150=18 Volts Clamping)...It's a good choice ? It' s enough to use just one like in picture, or it's better to use one on every IO of PIC ?
    Try a few. They may reset the PIC because 5.6 volts is very close to
    operating voltage of 5.0 volts.
    I use one on every lead external to the board.
    I would place the TVS in front of the volt reg to protect it also.
    Norm
    Dec 2008
    Ploiesti, ROMANIA
    If 5V6 it's not so good, what value do You suggest ?
    Dec 2007
    Finland
    Post
    Working voltage of TVS (or any protection comp) must be a little over max DC voltage to avoid current leakage thru protection comp.
    For de-rating you should use + 10-20%. This means that Vbr (breakdown voltage) value is important, it should be so much above normal DC voltage that you will never reach that in normal conditions.
    5.6Vdc is usable (Vbr for that is ~6.5V or bit higher). With higher Vdc components (e.g. 7-10V) you will have less leakage.
    BR,
    -Gusse-
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. Replies: 67
    Last Post: - 8th December 2009, 02:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
