Sharp ir distance sensor
Results 1 to 4 of 4
    Oct 2009
    malaysia
    Default Sharp ir distance sensor
    HI.I'M WORKING FOR MY FINAL YEAR PROJECT WHICH IS I MAKE TO MAZE MAPPER ROBOT.FOR THIS PROJECT I USE 3 IR SENSORS (sharp GP2D120XJ00F),2 12VDC MOTOR WITH ENCODER (PD3046) AND 1 PIC18F4550 MICROCONTROLLER.I HAVE MAKE THE SENSORS CODING SEPARATELY BUT I CAN'T COMBINE THE 3 SENSORS CODING INTO 1 CODING.I'VE TRIED TO COMBINE THE SENSORS CODE BUT IT'S DOESN'T WORK AT ALL.HOW CAN I COMBINE THE 3 SENSORS?THERE'S ANYBODY CAN HELP ME TO SOLVE THE PROBLEM.FOR YOUR INFORMATION, I CONNECT THE 3 SENSORS AT THE PORTA0-A2.I ATTACH MY SENSORS CODE BELOW:
    COMBINATION OF 3 SENSOR
    define osc 8
    defenition
    DEFINE CCP1_REG PORTC ' Hpwm 1 pin port
    DEFINE CCP1_BIT 2 ' Hpwm 1 pin bit
    DEFINE CCP2_REG PORTC ' Hpwm 2 pin port
    DEFINE CCP2_BIT 1 ' Hpwm 2 pin bit
    DEFINE ADC_BITS 8 ' Set number of bits in result (8, 10 or 12)
    DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
    MRCW1 VAR PORTD.4
    MRCCW1 VAR PORTD.5 'MOTOR RIGHT DRIVE
    MRCW2 VAR PORTD.6
    MRCCW2 VAR PORTD.7 'MOTOR LEFT DRIVE
    TRISD.4=0
    TRISD.5=0
    TRISD.6=0
    TRISD.7=0
    TRISA=1
    ADCON1=%00001110
    SENSOR1 VAR BYTE
    SENSOR2 VAR BYTE
    SENSOR3 VAR BYTE
    HPWM 1,150,1000
    main program
    MAIN:
    GOSUB fwd
    GOSUB IR1
    PAUSE 1000
    GOSUB IR3
    PAUSE 1000
    GOSUB IR2
    PAUSE 1000
    GOTO MAIN
    FWD:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=1
    HPWM 2,150,500
    MRCCW2=1
    MRCW2=0
    IR1:
    ADCIN 0,SENSOR1
    IF SENSOR1>46 THEN
    GOSUB RIGHT
    if SENSOR1<46 THEN
    GOSUB FWD
    IR2:
    ADCIN 1,SENSOR2
    IF SENSOR2>46 THEN
    GOSUB BWD
    if SENSOR2<46 THEN
    GOSUB fwd
    IR3:
    ADCIN 2,SENSOR3
    IF SENSOR3>46 THEN
    GOSUB LEFT
    if SENSOR3<46 THEN
    GOSUB FWD
    RIGHT:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=1
    HPWM 2,150,500
    MRCCW2=0
    MRCW2=0
    LEFT:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=0
    HPWM 2,150,500
    MRCCW2=1
    MRCW2=0
    BWD:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=1
    HPWM 2,150,500
    MRCCW2=1
    MRCW2=0
    PAUSE 1000
    GOSUB RIGHT
    FOR THE SEPARATE CODE OF SENSOR:
    SENSOR 1
    define osc 8
    'defenition
    MRCW1 VAR PORTD.4
    MRCW2 VAR PORTD.6
    TRISD.4=0
    TRISD.5=0
    TRISD.6=0
    TRISD.7=0
    TRISA.0=1
    ADCON1=%00001110
    SENSOR1 VAR BYTE
    HPWM 1,150,1000
    'main program
    MAIN:
    GOSUB fwd
    GOSUB IR1
    GOTO MAIN
    FWD:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=1
    IR1:
    ADCIN 0,SENSOR1
    IF SENSOR1>46 THEN
    GOSUB BREAK
    if SENSOR1<46 THEN
    GOTO MAIN
    GOTO IR1
    BREAK:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=0
    AND FOR SENSOR 2
    define osc 8
    'defenition
    MRCW1 VAR PORTD.4
    MRCW2 VAR PORTD.6
    TRISD.4=0
    TRISD.5=0
    TRISD.6=0
    TRISD.7=0
    TRISA.1=1
    ADCON1=%00001100
    SENSOR2 VAR BYTE
    HPWM 1,150,1000
    MAIN1:
    GOSUB FWD
    GOSUB IR2
    GOTO MAIN1
    FWD:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=1
    IR1:
    ADCIN 1,SENSOR2
    IF SENSOR2>46 THEN
    GOSUB BREAK
    if SENSOR2<46 THEN
    GOTO MAIN1
    goto IR2
    BREAK:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=0
    PLEASE HELP ME,I'M DESPERATELY NEED THE SOLUTION OF MY PROBLEM.THANK YOU.
    Wink
    Hi, hasnan ...
    First, could you write LOWERCASE ??? ... thanks for other's eyes !
    NOW, just Two Questions :
    1) Is there a Comparators module aboard the 4550 ???
    2) Do you think this is enough : " TRISA.1=1 " ???
    Oct 2009
    malaysia
    Default sharp ir distance sensor
    Hi Alain,
    For the answer of your question;
    1.Yes,i have the Comparators module aboard the 4550 which is this 4550 have analog comparators on PORTA and another port.I will attach the picture of PIC18F4550.These 3 sensors were connected through PortA0 to PortA2.
    2. Actually i used TRISA.1=1 just for test one of my sensor either it is function or not.I used the TRISA=1 so that all my 3 sensors active but the problem was from the instruction of ADCON1.there seems like the sensors not funtion when i used only 1 ADCON1 to combine all of 3 sensors.
    Last edited by hasnannordin; - 11th October 2009 at 05:23. Reason: attach the file
    Oct 2009
    malaysia
    Default IR sensor
    oh yes alain i forgot to attach my schematic diagram of my project.i will attached my circuit diagram for your reference.
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Ultrasonic distance sensor with PIC16F84A
    Last Post: - 29th June 2009, 10:01
  3. Need Help with GP2Y0A21 IR Sensor
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 25th January 2009, 12:51
  4. line follower - IR sensor
    By shirleyz in forum mel PIC BASIC Pro
    Last Post: - 29th May 2008, 13:14
  5. distance sensor
    Last Post: - 27th January 2006, 11:37
