Erratic analog inputs .
Results 1 to 9 of 9
    Lightbulb
    At first glance ...
    Your Vref must be rock-stable ( Pic Decoupling ... What about ???) ... now result is +/- 1 digit ... = +/- 5 mv !!! ... a little HardWare scheme would be useful !!!
    I'd recommend some external Vref ... if mV looked for !
    Aug 2009
    Cool For a test.
    Hi, I found a site that has a project that will help me setup mine. The project uses a potentiometer to vary the voltage to be read and display. It uses one port only ( portA.4) but for the test it’s good enough. I followed all the instructions and did the setup exactly as the program said. I copied the program and compiled it. The program describes that the displayed digital value will be from 0 to 1023. It worked as plan but the number displayed is a single digit not four as expected. This is the whole project site: C:\Documents and Settings\Dad\Desktop\mr k\adc2.pbp ,Please help me find what I am doing wrong. Thanks.
    Hmmmmm.
    For some reason I can not get into your "C" drive from here.
    Could be a network problem.
    Go over to rentron.com for some examples that work.
    And what are your voltages?
    Aug 2009
    Smile Found it!!!
    I found the problem by chance. I mist the DEFINE ADC_BITS 10 that gives me the precision. Thanks any ways to Charles, Acetronics and Mackrackit that so gently help me figure it out. You guys out there are our best teachers ever. Thanks.
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. Multiple analog inputs ?
    By rngd in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 16:13
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. Many Analog Inputs
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 10th July 2006, 09:15
  5. analog inputs on 16F716
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 6th October 2005, 05:07
