Hi All,
After searching a few threads with not quite the answers i'm looking for, i'd like to know what the preferable way is, to add TCP/IP into a PIC project.
I'm looking at using the ENC28J60 Ethernet interface, but not sure if that's the popular choice for a newbie?
From what i (mis)understand, some interfaces are somewhat intelligent and handle all the tcp/ip protocol itself, whereas the smaller cheaper interfaces are nothing more than a physical interface into the pic, and i'd need to code a LOT more low-level tcp-handling routines.....something i don't want to do.
So, trying to keep things as simply as possible, are there preferred interfaces i should go with? is there a 'how to get started/basics' thread hidden somewhere here or elsewhere on the net?
Ultimately, (like most people) i'd like to control my Pic project via the net (or internal network), simply toggling a bit on/off from a Webpage elsewhere would be nice, or serving a webpage telemetry/status indication that i can view anywhere would also be of great use.
Thanx in advance,
Marty.
