Adding TCP/IP Ethernet to PIC - how?
Results 1 to 40 of 65
    SWITZERLAND (french speaking)
    Default NANO module model and software or no-software?
    ...pins spacings are metric...it only does port 80...
    Thanks for the tips although I currently don't understand the importance of the port number
    I'm a little confused about which ConnectOne NANO module I need to order. Is it correct to choose part iL-SM2144H-I if I just need a module with pins, no WiFi, a RJ45 socket onboard? But then it is a Nano SocketLAN I want to buy not the Nano LANReach or am I wrong?
    One more question about the NANO module; as I will use it to update a server's clock using NTP (or SNTP), will I need an external program running on the server to handle the time information provided by the module or is the module capable to do it all by itself?
    According to Dave's post, the WIT110SR module could also be an option (http://www.wiznet.co.kr/Sub_Modules/...te3=0&pid=1040) but, at a first glance, it looks a little more complicated however it is half the price of the Nano (!).
    BTW, I just found ConnectOne's LAN modules comparision chart here here.
    Roger
    If you have one of these modules behind a router (NAT) and another device is configured for PORT 80, say Apache for a web sever, you will not be able to serve web pages directly from the module because it only listens on PORT 80 and this can not be changed. Same if you have it set as a HTPPS server, PORT 443 is all it will listen to. This all is not a problem on a LAN.
    The SERIAL NET function of these modules are not a problem, you can pick your port.
    The Nano Socket family are the ones I use, they have pins. The on board antenna on the wifi module is pretty good too.
    I am not sure how to answer this one.
    The module can be set to check certain time servers, it is a client.
    From your other thread I think I know what you want to do. Have your own time server on a LAN that is not connected to a WAN?
    If that is correct then I think it is doable...
    Where ever you are getting your time from could be sent to the module with a PIC and the module FTP, SERIAL NET, email,,, the data to the server. Then the server has a script to deal with the data... Kind of like I do for temperature data??
    Dec 2005
    I bought one of the modules with the itsy-bitsy socket because I wanted to see whether it was practical to incorporate it in by PCB design. I decided against it but the boards themselves were the same so I just added pins in order to use that first one in prototyping. One advantage of adding the pins myself was I could mount it atop or beneath my main PCB. BTW, the support techs at ConnectOne are very sharp and well orgaized - all my questions were answered by the same tech so there was no loss of continuity. (Either they are well organized or they only have one overworked support tech.)
    I know there are ways to push the time out to machines on a LAN but, as I've never had the need, I've never explored it. Search Bing (or Google?) using Time Synchronization Network (LAN) for details.
    Aug 2009
    Paso Robles California
    Default 1
    [QUOTE=dhouston;95970]I bought one of the modules with the itsy-bitsy socket because I wanted to see whether it was practical to incorporate it in by PCB design. I decided against it but the boards themselves were the same so I just added pins in order to use that first one in prototyping. One advantage of adding the pins myself was I could mount it atop or beneath my main PCB. BTW, the support techs at ConnectOne are very sharp and well orgaized - all my questions were answered by the same tech so there was no loss of continuity. (Either they are well organized or they only have one overworked support tech.)
    only one [email protected]
    Dec 2005
    Quote Originally Posted by l_gaminde View Post
    that's the one!
    Dec 2005
    I just noticed ConnectOne's Mini Socket iWiFi http://www.connectone.com/products.asp?did=73&pid=73 which uses 0.100 inch headers, making it easier to breadboard for experimenting.
    Aug 2009
    Default tcp/ip
    thats good news is it still 3volt
    Quote Originally Posted by mackrackit
    Yes, correct.
    No, just accurate time & date from a radio-controlled system (in Europe, it is DCF77 from GERMANY) or GPS module.
    Quote Originally Posted by dhouston
    ...if you are looking at a one-off design, it is ready to go out-of-the-box with no assembly required
    Yup, it's a one-shot project. Anyway, I need to design a PCB for the PIC and the DCF77 receiver. But your points are pertinent...and you make me doubt about the best choice I have to go for
    Let's do it a feminine way: keep the first impression as beeing the best one = NANO!
    Roger
    Dec 2005
    I'm assuming that you do not need to connect to a Network Time Server using NTP since you'll be getting the time wirelessly. You just need to then share that time with the machines on your LAN. I have no idea whether the nano can act as an NTP server, if it can then it may be the best choice but if you're going to have to write the code to push the time out over the LAN, the WIZ110SR would be my choice based on initial cost and its out-of-the-box readiness.
    ...You just need to then share that time with the machines on your LAN
    YES... and NO.
    The LAN is dedicated to a security CCTV and access control system. Time has to be "minute" accurate so I prefer to have a good time-base that will adjust the time once or twice a day or so.
    NANO does NTP according to its datasheet. Nevertheless, I'll have a deeper look @ WIZ110SR. Actually, I could buy both...and try!
    Thanks a lot for your advice... and experience too
    Roger
    hoi,
    fyi,
    I am using always PBP for all projects except ... if ethernet applic. needed.
    My son tested it and is quite easy if using basic 18F97J60 and
    libraries from yo2lio 'www.microelemente.ro'
    applications also with the ENC chip and smaller processors, webservers, videostreaming
    it's a pain with PBP, with MB it all works..
    sry
    rgds
    Aug 2009
    Default nano
    YES... and NO.
    Yes it does used this feature
    Dec 2005
    As I noted above, of the three (ConnectOne, Tibbo, WIZNet), the WIZ110SR will require the most coding on the PIC end but, if you are looking at a one-off design, it is ready to go out-of-the-box with no assembly required.
    If you are planning for volume and designing a PCB, I would go with ConnectOne or Tibbo and the choice would probably depend on the application. The Tibbo, with its own program memory offloads nearly all of the network coding but does mean you are working with two different Basic dialects. I think, if you study the docs I've referenced, you'll be most impressed with the Tibbo. I design projects that usually have some DIY elements and the flexibility of the Tibbo and the fact it is programmable in Basic make it attractive in that environment. Plus, users can reprogram as needed if I become totally incapacitated.
    BTW, when I bought my ConnectOne modules they had not released the SocketLAN so I added my own pins to the LANReach. I tend to use the latter term to apply to either.
  1. PIC and TCP/IP
    By jscoulter in forum mel PIC BASIC Pro
    Last Post: - 17th September 2009, 11:21
  2. PIC 18F97J60 and Ethernet
    By mikebar in forum mel PIC BASIC Pro
    Last Post: - 16th April 2008, 12:51
  3. Ethernet <> PIC link
    Last Post: - 16th November 2007, 12:04
  4. Adding a pic in I2C network....
    By robert0 in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2005, 12:07
