Hi every body
i m trying to blink some leds with pic 18f2550 using usb connection to my labtop
i have some problems
1- when i open vb2008 interface, it doesnt identify that usb is plugged untill i touch Vusb with my hand. i aready put 200nf capacitor to ground on Vusb. i is very strange.
2- when i send data to pic, i doesnt blink the leds. i revised vb code many times. and i revised my controller code also. i just cant find what is wrong.
plz help me. it driven me crazy. espicially when it needs my to provide a path to ground with my body on Vusb!!!
pic code
vb codeCode:DEFINE OSC 48 USBBufferSizeMax con 8 ' maximum buffer size USBBufferSizeTX con 8 ' input USBBufferSizeRX con 8 ' output ' the USB buffer... USBBuffer Var Byte[USBBufferSizeMax] USBBufferCount Var Byte ' ************************************************************ ' * main program loop - remember, you must keep the USB * ' * connection alive with a call to USBService every couple * ' * of milliseconds or so... * ' ************************************************************ usbinit ' initialise USB... ProgramStart: USBBUFFER[0] = 0 USBBUFFER[1] = "P" USBBUFFER[2] = "=" USBBUFFER[3] = 15 USBBUFFER[4] = "T" gosub DoUSBOut gosub DoUSBIn portb = usbbuffer[3] goto ProgramStart ' ************************************************************ ' * receive data from the USB bus * ' ************************************************************ DoUSBIn: USBBufferCount = USBBufferSizeRX ' RX buffer size USBService ' keep connection alive USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available return ' ************************************************************ ' * wait for USB interface to attach * ' ************************************************************ DoUSBOut: USBBufferCount = USBBufferSizeTX ' TX buffer size USBService ' keep connection alive USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data return
Code:Public Class frmUSB ' vendor and product IDs Private Const VendorID As Short = 4660 'Replace with your device's Private Const ProductID As Short = 1 'product and vendor IDs ' read and write buffers Private Const BufferInSize As Short = 8 'Size of the data buffer coming IN to the PC Private Const BufferOutSize As Short = 8 'Size of the data buffer going OUT from the PC Dim BufferIn(BufferInSize) As Byte 'Received data will be stored here - the first byte in the array is unused Dim BufferOut(BufferOutSize) As Byte 'Transmitted data is stored here - the first item in the array must be 0 ' **************************************************************** ' when the form loads, connect to the HID controller - pass ' the form window handle so that you can receive notification ' events... '***************************************************************** Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load ' do not remove! ConnectToHID(Me) Label2.Text = "Connected to HID" End Sub '***************************************************************** ' disconnect from the HID controller... '***************************************************************** Private Sub Form1_FormClosed(ByVal sender As Object, ByVal e As System.Windows.Forms.FormClosedEventArgs) Handles Me.FormClosed DisconnectFromHID() End Sub '***************************************************************** ' a HID device has been plugged in... '***************************************************************** Public Sub OnPlugged(ByVal pHandle As Integer) If hidGetVendorID(pHandle) = VendorID And hidGetProductID(pHandle) = ProductID Then ' ** YOUR CODE HERE ** Label2.Text = " USB plugged" End If End Sub '***************************************************************** ' a HID device has been unplugged... '***************************************************************** Public Sub OnUnplugged(ByVal pHandle As Integer) If hidGetVendorID(pHandle) = VendorID And hidGetProductID(pHandle) = ProductID Then hidSetReadNotify(hidGetHandle(VendorID, ProductID), False) ' ** YOUR CODE HERE ** Label2.Text = "USB unplugged" End If End Sub '***************************************************************** ' controller changed notification - called ' after ALL HID devices are plugged or unplugged '***************************************************************** Public Sub OnChanged() ' get the handle of the device we are interested in, then set ' its read notify flag to true - this ensures you get a read ' notification message when there is some data to read... Dim pHandle As Integer pHandle = hidGetHandle(VendorID, ProductID) hidSetReadNotify(hidGetHandle(VendorID, ProductID), True) End Sub '***************************************************************** ' on read event... '***************************************************************** Public Sub OnRead(ByVal pHandle As Integer) ' read the data (don't forget, pass the whole array)... If hidRead(pHandle, BufferIn(0)) Then ' ** YOUR CODE HERE ** TextBox2.Text = Str$(BufferIn(3)) Label2.Text = "Data recieved" ' first byte is the report ID, e.g. BufferIn(0) ' the other bytes are the data from the microcontroller... End If End Sub Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click End End Sub Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click BufferOut(0) = 0 'first byte is always the report ID BufferOut(1) = Asc("P") 'first data item BufferOut(2) = Asc("=") 'second data item BufferOut(3) = Val(TextBox1.Text) 'third data item to be send ober usb BufferOut(4) = Asc("T") 'fourth data item 'write the data, dont forget to send the whole array hidWriteEx(VendorID, ProductID, BufferOut(0)) hidWriteEx(VendorID, ProductID, BufferOut(1)) Label2.Text = "Data sent" End Sub End Class
