PIC16F877A PORTA.2 not working
Results 1 to 3 of 3
    Jun 2007
    Mansfield, UK
    Default PIC16F877A PORTA.2 not working
    Hi, I think i know the answer to this one but i want to double check. Ive got PORTA.2 connected to a transistor but it never turns on. Im pretty sure my settings are correct.
    'Chip settings
    ADCON0=0
    ADCON1=0
    CMCON=7
    CVRCON=0
    CCP1CON=0
    All special operations on that pin should be disabled. When i put my finger under the transistor the LEDs turn on so i know the transistor is working. When the PIC is connected they even flash. It seems like the PIC is turning that output on and off correctly but it doesnt actually go high. It seems to switch between low and floating.
    Is the chip supposed to do this or is this one broken? Will it be fine to add something like a 100K pull up resistor? (I think that might solve this problem)
    For an 877A, you only need one of those lines, but with a different value.
    ADCON1 = 7
    CMCON=7 ; already 7 on power-up
    ADCON0=0 ; already 0 on power-up
    CVRCON=0 ; already 0 on power-up
    CCP1CON=0 ; already 0 on power-up
    Jun 2007
    Mansfield, UK
    Thanks, Ill try that.
    Im going to leave the other lines there because last year im sure i had to add 2 lines to get it to work properly but i cant remember which 2.
  1. PIC16F877A analog problem
    By DeViLa_Q8 in forum mel PIC BASIC
    Last Post: - 30th July 2009, 21:19
  2. PIC16F877A for application in mobile robot...
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 15:47
  3. PIC16F877A not working again :(
    Last Post: - 30th October 2008, 01:04
  4. PIC16F877A not working
    By The Master in forum General
    Last Post: - 16th November 2007, 12:32
  5. Help Quick Need to make code smaller
    By Programmednew in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 04:46
