16F877A to 18F4550 comms
Results 1 to 6 of 6
    two reasons, i'm using PBP244 at this moment and acording to the manual their are two ways of doing interupts...
    in PBP using ONINTERUPT which then causes latency in the program...
    The other is in assembler and every time i read it i get a headach and don't understand it... It's alien compaired to what i'm used to...
    I do plan to buy the pbp260 upgrade in 2-3 weeks... perhaps that will help
    I can not remember if DTs Instants work with PBP244, might take a look at it.
    If I understand what you are doing tou would only need the interrupt on the 4550. When the 877A needs data the routine that called for it could wait there for a response, maybe for X time. If the 4550 is not doing much maybe on-interrupt would not be to slow.
    Just thoughts....
    the 4550 basically has a loop...
    read ADC1
    if ADC1 is over the on trigger variable then turn on B1
    If ADC1 is lower than off trigger var then turn off B1
    For every time B1 is turned on increment pulse count var
    If pulse count var = 4 read tmr1 and calculate RPM
    Reset TMR1 and restart loop
    The faster the cycle the better...
    The addition would be to recieve a new ON and OFF trigger var from the 877A
    The single byte 'commands' comming from the 877a are...
    * Stall warning - return to predefined static settings
    * Overspeed1 - stop pulsing
    * Overspeed2 - engage emergency break (relay on B2)
    The 877a will only be changing one var every 5 seconds or so...
    The 877a will be doing all the work and the calculations and putting data on the LCD...
    I don't know 'DTs instants' i'm guessing i go do a search for it... lol
    I am sure you found it but if not
    http://www.picbasic.co.uk/forum/showthread.php?t=3251
  1. 16f877A V 18F4550
    By comwarrior in forum General
    Last Post: - 21st October 2009, 19:34
  2. 16F877 vs. 16F877A
    By DavyJones in forum General
    Last Post: - 11th April 2009, 18:22
  3. 18F4550 to 18F2550
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 28th September 2007, 23:13
  4. How can I turn off USB support in 18F4550
    Last Post: - 6th September 2007, 03:56
  5. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 18:52
