I have been trying all day to run this program on a 16F628 and the damn thing does not.
I can't believe that I cannot make it run. Oh God I am gonna smash it.
I'll give it a chance.
Please if anyone can see what I am missing, please help.
Chip is 16F628 with ceramic resonator. Checked the freq and is close to 4MHz. Also the Option_Reg seems to be configured OK because of the Pull ups checked on port B, but then, nothing happens...
INCLUDE "C:\PBP\MODEDEFS.BAS"
;----- Configuration bits ------------------------------------------------
@Line1 = _LVP_OFF & _BODEN_ON & _DATA_CP_ON
@Line2 = _CP_ALL & _MCLRE_ON & _PWRTE_ON & _WDT_ON & _XT_OSC
@ __CONFIG Line1 & Line2
cmcon=7	    		'disable portA comparators
intcon=0		'disable interrupts
vrcon=0			'disable reference voltage output at porta.2
TRISA = %00000000	'PA0:
			'PA1:
			'PA2:
			'PA3:Relay
			'PA4:Buzzer
			'PA5:
TRISB = %01110010	'PB0:
			'PB1:Serial Input
			'PB2:Serial Output
			'PB3:RS485 Direction
			'PB4:D0
			'PB5:D1
			'PB6:Button
			'PB7:
option_reg=%00000000
relay       var porta.3
buzzer      var porta.4
dir         var portb.3
d0          var portb.4     'Wiegand D0 input
d1          var portb.5     'Wiegand D1 input
but         var portb.6	'Button input
data_array  var byte[3]     'Wiegand data array
byte_1      var data_array[2]
byte_2      var data_array[1]
byte_3      var data_array[0]
clear
high buzzer:pause 500:low buzzer
stop
