How to read stored data from MCU EEPROM into PC?
Results 1 to 3 of 3
    Quote Originally Posted by jellis00 View Post
    My problem is I can't figure out how to use Hyperterminal to read the accumulated EEPROM data residing in the PIC mictrocontroller's internal EEPROM. Does anyone have any PC software to do this or suggestions how I should accomplish this??
    When the PIC reads the EEPROM and sends it out to the terminal format the string with a comma in it so the terminal displays
    "VAR1,yourDATA1"
    "VAR2,yourDATA2"
    and so on....
    Then either copy paste the terminal or save to a text file. Open the file in excel as a comma delimited.
    Or are you looking for something more automatic?
    This is how I'd do it;
    Say your variable is 'N'.
    Put the line "DEBUG #N,13,10" in a loop.
    When it stops, copy the output from Hyperteminal, and just paste it into Excel. All the data items should appear in the column you've pasted into.
    Things become slightly more complex if you have more than one entry per record, to be pasted into 2 or more columns, but for single columns this should work fine.
    Anand
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  3. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
