Heating a facility box in winter time.
Results 1 to 7 of 7
    Default Heating a facility box in winter time.
    I have a metal box with some electronics inside.
    This boxis going o be placed in a place where in winter temp. can be very low.
    The volume of the box is about 2 liters and I want to calculate how much energy is going to be needed for the internat temperature not be below say of 5 degrees when the outside may be -20 Celsius.
    A big heatsink with a power transistor is the possible solution the heat the box, but how many watts are needed to do that in relation to the temperatures?
    Wink How long takes the gun muzzle to cool down ???
    Hi, Ioannis
    Some more info are necessary ...
    - box placed in an open place ??? ( rain or snow can cover it ???)
    - box vertical or Horizontal ( I or __ )
    - put on a shelf ???
    - is there "wind" around ( forced convection ? )
    not so simple a Thermal convection problem ...
    PS: Title is a French Humorist ( Fernand Reynaud ) Well known BIG success of the 70's ...
    Hi Alain.
    Thanks for the reply. Well, the box is in the open space but protected from rain/snow.
    It will be in vertical position so the heat sink is going to be place on the bottom.
    Mounted on a wall.
    As it is in the open, I intent to put some insulation on the inner walls of the box.
    Sure is not easy problem...
    Talking
    LOL ...
    I just forgot to ask for the main data : your box dimensions !!!
    About 2 lt. Exact dimensions are to be determined.
    they are needed ...
    Even approximative ( 10 cm , 50 cm , 2 meters ??? ) just to fix the power range ...
    OK. 30x40x25 will be close enough.
    Thanks, Ioannis
  1. I don't understand this code!
    Last Post: - 13th February 2008, 03:55
  2. Measuring time
    By AugustoPedrone in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 00:46
  3. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 20:55
  4. Alarm Time
    By Santana in forum Code Examples
    Last Post: - 8th December 2006, 14:58
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 15:24
