PIC based SONAR
Results 1 to 2 of 2
Thread: PIC based SONAR
    PICtron's Avatar
    PICtron Guest
    Default PIC based SONAR
    could someone help with a schematic for a SONAR?
    Requirements and findings so far:
    I have got a Transducer tuned at 200kHz.
    (Receiver and transmitter consisting of a single piezo, so only two wires)
    The available Supply Voltage will be 12 VDC.
    The general idea is to send out a "burst" of about 10 pulses at 200kHz.
    Then short the Transducer for a short period if time to stop it from resonating.
    Then measure the time for the echo to come back.
    So far it sounds simple,
    but to increase the amplitude of the burst
    I would like to reverse the polarity of the two wires of the transducer
    rather than having one wire tied statically to GND and sending HIGH's and LOWs to the second wire.
    The Transducer will draw quite some power when active, so I will certainly have to use MOSFETs.
    Any Input will be appreciated.
    Dec 2003
    Wichita KS
    Hello Pictron,
    PICtron>>The general idea is to send out a "burst" of about 10 pulses at 200kHz.
    rather than having one wire tied statically to GND and sending HIGH's and LOWs to the second wire.<<
    Remember that sound travels MUCH faster in water, than in does in air.
    Depending on your distance, 10 pulses is probalby way too many. maybe one pulse is the answer with a timeout of X Mils<g>.
    Dwayne
    Ability to Fly:
    Hurling yourself towards the ground, and missing.
    Engineers that Contribute to flying:
    Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute
    Pilots that are Flying:
    Those who know their limitations, and respect the green side of the grass...
  1. Talking Clock (Pic Based)
    By Art in forum General
    Last Post: - 20th January 2012, 15:45
  2. Replies: 6
    Last Post: - 11th November 2007, 22:14
  3. PIC Based Inductance Meter
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 16th October 2007, 03:34
  4. Easy pic based infrared
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 14th January 2006, 20:52
    Last Post: - 12th March 2005, 00:14
