LCD freeze
Results 1 to 4 of 4
Thread: LCD freeze
    Sep 2005
    France
    Default LCD freeze
    HI,
    I'm using a 16f648A running at 4MHz. Using usart @ 9600Bds
    When many data are received, sometimes the LCD freeze, sometimes not...
    Any help ?
    ' * Programme de gestion de l'afficheur LCD    *
    ' *      relié à la carte de commande des        *
    ' *       des atténuateurs programmables.       *
    ' *  	nom du programme: affmtouch.bas        *
    ' *     PIC16f628, marquage CI: 10C              *
    ' définition des pins utilisées
    'a.0 = LCD D4
    'a.1 = LCD D5
    'a.2 = LCD D6
    'a.3 = LCD D7
    'a.4 = LCD RS avec pullup
    'b.1 = RX
    'b.3 = LCD Enable
    'b.4 = détection mode auto/manuel
    CMCON = 7
    trisa = %00000000
    trisb = %00010010
    portb = 0
    c1	  var  	byte
    d1	  var 	byte
    u1	  var   byte
    c2    var   byte
    d2    var   byte
    u2    var   byte
    c3    var   byte
    d3    var   byte
    u3    var   byte
    c4    var   byte
    d4    var   byte
    u4    var   byte
    voie  var   byte
    x     var   byte
    name  var   bit         ' mode rename
    mode  var   bit         ' 1 = automatique
    da1   var   byte        ' digit 1 du nom de la premiere voie
    da2   var   byte
    da3   var   byte
    da4   var   byte
    db1   var   byte
    db2   var   byte
    db3   var   byte
    db4   var   byte
    dc1   var   byte
    dc2   var   byte
    dc3   var   byte
    dc4   var   byte
    dd1   var   byte
    dd2   var   byte
    dd3   var   byte
    dd4   var   byte
    n1    var   byte
    n2    var   byte
    n3    var   byte
    n4    var   byte
    dgt   var   byte
    dgt1  var   byte
    dgt2  var   byte
    dgt3  var   byte
    dgt4  var   byte
    GP    VAR   BYTE     ' GP variable
    BytesIn VAR BYTE[30] ' Up to 30 bytes
    ByteCnt VAR BYTE     ' Index pointer
    OERR    VAR RCSTA.1  ' Alias USART over-run bit
    CREN    VAR RCSTA.4  ' Alias USART continuous receive enable bit
    RCIF    VAR PIR1.5   ' Alias USART received character interrupt flag bit
    pos  var    byte     'position du curseur LCD
    val  var    byte
    pause 10				'10 milli secondes de pause
    c1 = 0
    d1 = 0
    u1 = 0
    c2 = 0
    d2 = 0
    u2 = 0
    c3 = 0
    d3 = 0
    u3 = 0
    c4 = 0
    d4 = 0
    u4 = 0
    x = 0
    pos = 1
    RCSTA = $90 ' Enable serial port & continuous receive
    TXSTA = $24 ' Enable transmit, BRGH = 1
    SPBRG = 25  ' 9600 Baud @ 4MHz, 0,16%
    INTCON = 0  ' Disable interrupts
    ByteCnt = 0
    high portb.7
    debut:
        IF PORTB.4 = 1 THEN
        LCDOUT $FE,2,"    mode: remote      "
        mode = 1
        LCDOUT $FE,2,"    mode: manual      "
        mode = 0
        dgt1 = 32   'espace
        dgt2 = 32
        dgt3 = 32
        dgt4 = 32
        LCDOUT $FE,$94,"---------+---------"
        IF mode = 0 AND PORTB.4 = 1 THEN   'si passage en mode auto
        mode = 1
        IF mode = 1 AND PORTB.4 = 0 THEN   'si passage en mode manuel
        mode = 0
        IF RCIF THEN       ' If RCIF=1 there's a new character in RCREG
        BytesIn[ByteCnt]=RCREG ' Yes. Then store character in array
        IF BytesIn[ByteCnt]=10 THEN OutMsg ' LF (0A)
        ByteCnt=ByteCnt+1 ' Increment element index pointer
        IF !OERR THEN Main ' If NOT over-run, then re-cycle
        CREN = 0           ' Yes. Over-run condition is present, so clear it
        CREN = 1           ' Re-enable & clear over-run condition
    OutMsg:
    IF BytesIn[0] = 82 THEN rename    '(R) passage en mode rename
    IF BytesIn[0] = 65 THEN    ' (A) rx normal de la comatt
    for x = 13 to 28
    IF BytesIn[x] < 48 or BytesIn[x] > 90 then  'ASCII valide (nom des voies)?
    gosub reset
    goto Main
    next x
    for x = 1 to 12
    IF BytesIn[x] < 48 or BytesIn[x] > 57 then  'ASCII valide (chiffres seuls)?
    gosub reset
    goto Main
    next x
    c1 = BytesIn[1]
    d1 = BytesIn[2]
    u1 = BytesIn[3]
    c2 = BytesIn[4]
    d2 = BytesIn[5]
    u2 = BytesIn[6]
    c3 = BytesIn[7]
    d3 = BytesIn[8]
    u3 = BytesIn[9]
    c4 = BytesIn[10]
    d4 = BytesIn[11]
    u4 = BytesIn[12]
    da1 = BytesIn[13]
    da2 = BytesIn[14]
    da3 = Bytesin[15]
    da4 = BytesIn[16]
    db1 = BytesIn[17]
    db2 = BytesIn[18]
    db3 = Bytesin[19]
    db4 = BytesIn[20]
    dc1 = BytesIn[21]
    dc2 = BytesIn[22]
    dc3 = Bytesin[23]
    dc4 = BytesIn[24]
    dd1 = BytesIn[25]
    dd2 = BytesIn[26]
    dd3 = Bytesin[27]
    dd4 = BytesIn[28]
    IF c1 = 48 THEN
    c1 = 32
    IF c2 = 48  THEN
    c2 = 32
    IF c3 = 48  THEN
    c3 = 32
    IF c4 = 48  THEN
    c4 = 32
    LCDOUT $FE,$C0,c2,d2,".",u2," ",db1,db2,db3,db4,"| ",dd1,dd2,dd3,dd4," ",c4,d4,".",u4
    LCDOUT $FE,$D4,c1,d1,".",u1," ",da1,da2,da3,da4,"| ",dc1,dc2,dc3,dc4," ",c3,d3,".",u3
    GOsub reset
    gosub reset
    goto Main
    reset:
    FOR GP=0 TO ByteCnt ' Clear array bytes 0 to ByteCnt
    BytesIn[GP]=0
    NEXT GP
    ByteCnt=0           ' Reset index pointer back to first element
    WHILE RCIF          ' Trash any left over characters in RCREG buffer
    GP=RCREG            ' after EOM is received
    WEND
    rename:
            LCDOUT $FE,1," Rename "
            select case BytesIn[1]
                case 48
                n1 = da1 : n2 = da2 : n3 = da3 : n4 = da4
                case 49
                n1 = db1 : n2 = db2 : n3 = db3 : n4 = db4
                case 50
                n1 = dc1 : n2 = dc2 : n3 = dc3 : n4 = dc4
                case 51
                n1 = dd1 : n2 = dd2 : n3 = dd3 : n4 = dd4
                case else
            gosub reset
                end select
            lcdout n1,n2,n3,n4
            LCDOUT $FE,$C0," Press: Max to enter"
            lcdout $FE,$94,"        Min to Exit"
            gosub reset
    'attente que la comatt envoie le "V" de validation ou "Go" exit
    loop1:
            IF BytesIn[ByteCnt]=10 THEN outloop1 ' LF (0A)
            IF !OERR THEN loop1 ' If NOT over-run, then re-cycle
            goto loop1
    outloop1:
            IF BytesIn[0] = 71 then       '(G) sortie de ce mode
            GOSUB reset
            GOTO debut
            IF BytesIn[0] = 86 then      '(V) affichage des lettres alphabet
            gosub reset
            dgt = 0
    alpha:  dgt = dgt + 1
            LCDOUT $FE,1," select +/- Then Max"
            LCDOUT $FE,$C0," 0123456789ABCDEFGHI"
            LCDOUT $FE,$94,"JKLMNOPQRSTUVWXYZ"
            lcdout $FE,$D4,dgt1,dgt2,dgt3,dgt4
            lcdout $FE,$C0
            lcdout $FE,$0F
            if dgt = 5 then
            lcdout $FE,$0C
            goto debut
    loop2:
            IF BytesIn[ByteCnt]=10 THEN outloop2 ' LF (0A)
            IF !OERR THEN loop2 ' If NOT over-run, then re-cycle
            goto loop2
    outloop2:
            IF BytesIn[0] = 43 then    '+
            pos = pos + 1
            IF pos = 21 then
            lcdout $FE,$94
            gosub reset
            goto loop2
            lcdout $FE,$14
            gosub reset
            goto loop2
            If BytesIn[0] = 45 then    '-
            pos = pos - 1
            if pos = 20 then
            lcdout $FE,$C0
            for x = 1 to 19
            lcdout $FE,$14
            next x
            gosub reset
            goto loop2
            lcdout $FE,$10
            gosub reset
            goto loop2
            if dgt = 1 then
            dgt1 = BytesIn[0]
            if dgt = 2 then
            dgt2 = BytesIn[0]
            if dgt = 3 then
            dgt3 = BytesIn[0]
            if dgt = 4 then
            dgt4 = BytesIn[0]
            pos = 1
            gosub reset
            goto alpha
    Sep 2005
    France
    Default maybe it takes long times for lcdout ?
    HI
    I think there are too much datas on the RX... and loop + lcd display takes too much time to execute...
    May be using another resonator 8MHz vs 4MHz ?
    I don't know how to optimize the code...
    Any help ?
    I have been looking at you code some and do not see where the problem is.
    Can you point to the routine where the problem starts?
    Other than that you may try adding a
    PAUSE 50
    between the LCDOUT commands and Play with these values
            ' Set command delay time in us
    	DEFINE LCD_COMMANDUS	2000
    	' Set data delay time in us
    	DEFINE LCD_DATAUS	50
    Sep 2005
    France
    Default It's OK now
    I have tried so much things....
    The only one that works, a new osc 8MHz Vs 4MHz !!!
    PS: Thank You Dave !
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
