How to read Speedo at low speed
Results 1 to 18 of 18
    The problem I have is the pic has to act quickly, the engine revs very quickly, and if it spends 1 second counting pulses, it will probably be over-revving by then.
    Of course, at 1 kph, the pulse period is 2.2 seconds, and that's how often you can update the display. But at 1kph, you don't need a faster refresh.
    Hi, folks ...
    Problem is Here, not a display problem ...
    You need quasi " real-time updated speed " ( Cf Post # 2 ) ...
    PS, Don't tell " Davewanna" , BUT
    "Dave would have liked to" ... Humour !
    I've tried ... but I don't understand what you mean Alain.
    He's reading the Speedo.
    If the engine revs fast, then so will the speed sensor.
    And you'll no longer be going 1kph.
    BTW, where'd he go.
    Dec 2007
    Default sorry
    Sorry all! Something unexpected has come up over the last 2 days. I didn't realise I had this many replies! I haven't even had a chance to read over everyone's suggestions yet... I will go through it all and post again.
    Very thankful for all the assistance!
    Cheers
    Wink The problem terms problem ....
    Hi, Darrel
    At school, I just learnt to carefully read the Problem terms :
    sampling every 100ms
    The unit is based on a 16F877a running at 4mhz (I can run it faster if I have to) It also controls the air-conditioning & thermo fans in a climate control kind of way, aswell as having a 20x4 display that gives me info on engine stats and temperatures.
    I do know forumers are not so clear in what they look for ... but I do whith what I have under the eyes ...
    Dec 2007
    Darrel,
    From your advice I guess my quickest easiest way of making this work is with pulsein (seeings I have very little interrupt knowledge yet)
    My reference to 21kph was if I use COUNT to count pulses over a 100ms period.
    I will try this in the next few days, with a pulsein timeout period of about 200ms (to prevent all the other functions from slowing down too much.)
    I still haven't had enough time to go over what everyone has posted. But rest-assured it is appreciated.
    Thanks!
  1. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  2. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  3. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  4. Replies: 14
    Last Post: - 26th September 2007, 06:41
  5. 4-line LCD Help - using PortA instead of B
    Last Post: - 31st March 2005, 04:14
